Old 06-11-2013, 10:50 PM
Most aftermarket radiators for Camaros are like that. I haven't had any issues...the hoses do much of the flexing.
If you do want to use the bottom saddle mount and top cap run a radiator spec't for a 69-72 Nova.
Old 06-12-2013, 11:14 AM
I have the C&R radiator and have been advised by them and others to use some rubber. Here is an email they sent me on the topic:
What you don’t want to happen is the radiator to become a weight bearing structural part of the car. Hard bolting it in would make the radiator flex with the car and allow no place for the radiator to expand/contract as it heats and cools. These issues will shorten the life of the radiator and lead to tubes breaking away from the header sheet and you get a leak that is hard to repair. Rubber grommet mounts are one method to give the radiator a way to expand. We use pin mounts with grommets on some radiators but if yours bolts directly to the core support, you can HARD bolt one side but on the other either OVER SIZE the holes you’re bolting through, SLOT them to allow for expansion or use a rubber grommet. All will allow the radiator to move as it needs to. If you have any further questions give me a shout.
Old 09-25-2013, 08:43 AM
dcrider69 dcrider69 is offline
I thought they were solid mounted from the factory? Why fix what ain't broke?
Old 09-25-2013, 09:26 AM
chr2002ca's Avatar
chr2002ca chr2002ca is offline
I believe 'stock mounts' for a '69 radiator use rubber 'well' nuts, which expand into holes of the core support as you tighten them.
http://www.heartbeatcitycamaro.com/s...967-1968-1969/
The 2 different aftermarket radiators I've had mounted this same way also.
Chris Robinson
1969 Camaro SS/RS, 489 ZL-1 MPFI, T-56 Mag
Old 09-25-2013, 11:06 AM
Correct, and this method is what I have always used also. But those little guys cant offer too much room for twisting/movement.
Old 09-25-2013, 06:07 PM
clill's Avatar
clill clill is offline
Use some type of rubber so stuff can flex etc. Especially on a car that has stiffer suspension and might get worked hard on a track etc.
Old 11-12-2013, 10:14 PM
jovozx12's Avatar
jovozx12 jovozx12 is offline
I would prefer to always rubber mount if possible but not radiators are rubber mounted. My jeep is hard mounted from the factory. Rubber mount is nice but not mandatory.
