Old 06-26-2013, 04:15 PM
rat_rod_russell's Avatar
rat_rod_russell rat_rod_russell is offline
Originally Posted by ChuckDriver View Post
Nice work Russell! Just a quick question, will the battery be on the firewall or will you be putting it some where else?
Thanks!
There will be room on the frame in the bed as well as room under the passengers seat but people who want to run their battery in the stock location will be able to as well. We might make a kit to mount it down there but we'll probably just leave that to you guys.
Russell what other frames do you plan on building?? 2nd gen??? just a thought.
Right now we do the 55-57 Passenger cars and we're devolving the 55-59 Trucks here an now. My plans are more trucks, A-bodies and C2/3 Corvettes. I'm not really planning anything for the F-bodies because I feel that the market is hugely over saturated but if enough people beat on my door I might change my mind. I'm always listening and making tally's on my list here at the shop. I've even got a few requests for 57 Cadillac frames on the list. But C10's have the top spot closely followed by the A-bodies. I feel the Corvette will be a good place as well. 63-83, 19 years in one frame, that's a hard market to overlook.
Originally Posted by ScottieB View Post
Can't wait to see this build unfold. We will have to talk when my Nomad is finished as I want something for my 61 bubble top.
NICE! They are longer at 119 but you might be able to mod one of the TriFive frames to fit with some work. Y'all should check out Scott's 55 Nomad project, https://lateral-g.net/forums/showthread.php4?t=41965
Thanks again
-Russell
PT-57
1957 Chevy Truck, 6.0L LS, T56, STS Twin Turbos, C6 Corvette Suspension, CAD Designed Frame by Hot Rod Jim's.
https://lateral-g.net/forums/showthread.php4?t=20292
http://www.nerdrods.com
Old 06-26-2013, 07:59 PM
So I just got a little more data into the computer about the bed and then I remembered. For a no body modifications frame the floor board of the cab and the motor aren't the biggest problem...... Its the bed and the rear suspension. Turns out at 6" off the ground the bed hits the differential pretty badly. So we're going with 8" off the ground as your "I want corvette suspension but I don't want to cut my body period!" option seen here. This will give you miles under the hood and a completely stock bed as well for guys who just want to buy everything OEM stock ish for finish out.
And 4" off the ground, seen here. The frame will be shaped as such that even this low you won't need to cut the bed steel braces just the wood to clear.
And just for you guys who didn't know this is 14" off the ground or STOCK!
And for it to all make more since here's a cool animation. Click to see the 1080 version with more detail, Warning the image is huge by computer standers so it might take a few to download.
I'm going back to work, you kids keep those question coming. Its egging me on!
Later
-Russell
PT-57
Old 06-29-2013, 01:19 PM
Updates!
We're making room for lots of tire out back for guys who NEED it and still make it easy to build and fit the 8" ride height without body modifications.
I know a few guys were having trouble with the grid looks so I colored in the sections to make it look correct. Also these are 20" wheels front and rear at the request of the customer to see what they would look like. Again one at 4" and one at 8".
Later
-Russell
PT-57
Old 06-30-2013, 11:44 AM
Transmission looks like its going to be cake. This is a 4L60E model and its got tons of room. I couldn't find my 4L80 model on the computer.
So the customer asked me to CAD up his wheels to see what they would look like. These are 18" Foose Nitrous II 18" with 245/40/R18 up front and 275/40/R18 out rear.
Also did some pocketing magic and now we've got an even longer shock (we already offered more wheel travel than the major competition.) And I've got miles of room for Ridetech Shockwaves, We area dealer for Ridetech as well so I hope to have that kit worked out soon enough.
Last note, We we'll make these frame rails air tight. You will be able to use the frame as an air tank and no have to mount it anywhere.
Thanks again
-Russell
PT-57
Old 07-14-2013, 12:30 AM
Update time. I'm having to pocket the suspension cradle into the tubing rail on this frame compared to older designs for other cars. Got room for the Air Ride on the back for guys who want to run that way and I'm making room for all the body mounts right now.
PT-57
Old 07-14-2013, 11:23 AM
Hotrod1's Avatar
Hotrod1 Hotrod1 is offline
I wish your frame kit was around before I started my stock frame alteration. Makes me want to build another one. Great work and looks like it is going to be nice finished product. Seems like the price is going to be good for the weld it your selfs out there.
Old 07-15-2013, 06:06 AM
aggie91's Avatar
aggie91 aggie91 is offline
Wow, this it going to be a killer truck when complete. I can see how the Nerd fits into Nerd Rods. You guys have some cool toys to use!
Karl
1965 Chevrolet C10
1982 Chevrolet C10 - My son's Truck - Sunburn
Tags
corvette, pickup, suspension, truck, weld
