I've thought of using spacers to raise the height of the gas pedal assembly......but I never pulled the trigger, this thread has inspired me to get back on that idea!!!
We did exactly that on TOW. By raising the gas pedal and dropping the brake pedal a little, we found a much better match on the gas/brake pedal heights. I was pretty unhappy with them at first also!
Are you kidding me? Pretty much the identical issue in the 2nd Gen as well. I searched a truckload of aftermarket pedal sets that don't solve the issue.
I did end up with a set of Modo Innovations pedals as they were the best looking. The biggest issue is the massive difference in height between the brake and gas pedals. I've thought of using spacers to raise the height of the gas pedal assembly......but I never pulled the trigger, this thread has inspired me to get back on that idea!!!
Great job Sieg, wonderful fabrication!!
Nice job Sieg.
Originally Posted by intocarss
I did the same but your bracket looks nicer Good job Mr Seig
Nice Job man! That's a great solution to a problem I wish we had. Drive-ability! Right now our drives like it is on rails! Wait a minute, it is on rails, 10" beams to be exact.
