Old 06-28-2013, 08:10 AM
intocarss's Avatar
I did the same but your bracket looks nicer Good job Mr Seig
Old 06-28-2013, 08:16 AM
Sieg's Avatar
Sieg Sieg is offline
Originally Posted by protour73 View Post
Are you kidding me? Pretty much the identical issue in the 2nd Gen as well. I searched a truckload of aftermarket pedal sets that don't solve the issue.
I did end up with a set of Modo Innovations pedals as they were the best looking. The biggest issue is the massive difference in height between the brake and gas pedals. I've thought of using spacers to raise the height of the gas pedal assembly......but I never pulled the trigger, this thread has inspired me to get back on that idea!!!
Great job Sieg, wonderful fabrication!!
We did exactly that on TOW. By raising the gas pedal and dropping the brake pedal a little, we found a much better match on the gas/brake pedal heights. I was pretty unhappy with them at first also!
Nice job Sieg.
Thanks Gentlemen
You too Dawgy!
Old 06-28-2013, 09:14 AM
ccracin's Avatar
ccracin ccracin is offline
Nice Job man! That's a great solution to a problem I wish we had. Drive-ability! Right now our drives like it is on rails! Wait a minute, it is on rails, 10" beams to be exact.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 06-28-2013, 12:19 PM
DaleTx's Avatar
DaleTx DaleTx is offline
Thanks Dale.
I'm interested, limited time - early departure required, what time do you plan on getting there?
I am free on Wednesday so I can go early. Let me know what time works for you and I'll meet you there
I'll buy you a Hefeweizen
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
Old 06-28-2013, 12:53 PM
Sieg's Avatar
Thanks Chad I was thinking maybe I should make a few pedals...........dollies might be a better idea.
Beer! What time do the gates open? I'd like to be heading south around 7 pm.
Old 06-28-2013, 01:45 PM
DaleTx's Avatar
Very cold Hefe'... with a lemon slice... 3:30 pm Ok ?
Mario Andretti
Old 06-28-2013, 07:07 PM
Track Junky's Avatar
Great job on the pedal Sieg. You might have to start putting those into production
Gaetano Cosentino
Old 06-28-2013, 07:20 PM
Sieg's Avatar
That should work, I'll try to leave here around 12:45-1:00.
Old 06-28-2013, 07:27 PM
Sieg's Avatar
I've been thinking.......
What's reasonable price range in your opinion?
All aluminum has potential, but pivot wear would need to be addressed.
Old 06-28-2013, 07:36 PM
Cost plus 300% plus shipping
Gaetano Cosentino
