Old 06-28-2013, 01:18 AM
Track Junky's Avatar
You make a good point Payton but dont you think 25 seems a bit low? I know I should be checking this with oil temps but when I was recently checking oil pressures I brought my water temps to 205 and at 750 rpm, my oil pressure was 48 lbs.
Temp at T-Hill this Sunday is supposed to be 106. I dont think I will do all 5 sessions.....most likely three......I'll get a better idea of what kind of oil pressures I'm running at idle after a few sessions and then make a call from there.
Gaetano Cosentino
Old 06-28-2013, 01:21 AM
Weight distribution yes, but it's about the farthest run possible for the lines to get to the motor when it needs it.
I don't know the part well enough to make that call (in other words are the hoses pressurized at all times?), but I believe Canton approved that placement.
Hopefully Chris jumps in here
I think the safest bet would be the shortest run.
Gaetano Cosentino
Old 06-28-2013, 01:31 AM
Finally...
BTW, Thanks for looking out
An accumulator is simply a pressure equalizer. You can have 15 lbs of oil pressure and the cylinder is full. The solenoid keeps the accumulator from dumping it's load in the pan when you shut off the motor and it helps build oil pressure faster than with an open manual valve. Keep in mind that you only put 6 lbs of air pressure on the back side of the accumulator piston. That's why it takes 5 seconds for the cylinder to empty with the engine off. For convenience, I like the solenoid.
I agree, I think the solenoid is the way to go. If your outside of the car closing the valve you cant see what the oil pressure is.
Gaetano Cosentino
Old 06-28-2013, 09:15 AM
Payton King's Avatar
Default Please know all of this is second hand info
as I have never had one on a car. The way it was explained if you are having oiling issues where the pressure is dropping or the pump is sucking air, the pan is not baffled well enough and/or the motor is pumping all the oil to the top of the motor and it is not draining back fast enough. The accusump is supplying oil to keep the pump covered up...better way than adding an extra quart or so and not having one.
Most engine builders will tell you that you can run low pressure (20 lbs) for a short amount of time and not do any damage. You are just trying to keep it from sucking air and having no oil to the bearing.
When Ron (blue 66 mustang) blew his wet sump LS7, it was a combination of a stock LS3 pan, oil pumped to the top of the motor and a long sweeping corner and the remainder of the oil went up the side of the pan and starved the bearings.
Old 06-28-2013, 09:36 AM
Since my pressures are high it leads me to believe that I might suck the pan dry. I know pressure isn't the same as volume but how could I possibly calculate. I think in my case 25 might be a bit low. 40 does sound a bit high. I'll start asking questions but I imagine I'll be at least at a 30.
Gaetano Cosentino
Old 06-28-2013, 09:55 AM
A properly plumbed accumulator will use a one way valve or drain back filter so the oil is pushed from the accumulator right into the main galley. Payton is right, it will lube the crank and fill the pan so the pump doesn't cavitate. There is a pressure gauge on the accumulator with the manual valve. You just subtract the 6psi precharge off the total. I would simply rev up the engine with my right hand and close it at say 60 or 70 psi.
Old 06-28-2013, 10:07 AM
intocarss's Avatar
150% correct
Old 06-28-2013, 11:37 AM
There's no way you are sucking the pan dry of your oil level is correct.
You have the proper pick up, appropriate capacity, adequate returns and trap doors to keep your pick up primed.
Pressure will not do it volume will.
Old 06-28-2013, 11:45 AM
With as fast as you are and a constantly improving suspension with tuning I am surprised this motor has lasted as long as it has without an accusump or dry sump.
Old 06-28-2013, 11:51 AM
With his increased speeds and forces he will be seeing soon its going to have to happen but not at the expense of other very important aspects of the car that shall be left unidentified.
Gaetano and I need to sit down and pin point actual issues and correect them. Doing that on a budget is tough on all of us. One change at a time.
