Old 06-30-2013, 07:12 PM
Just got home. Had a good time. If the track wasn't so slick from the heat I probably would have had a great time. The track was very, very slick. In all the years I have been doing this I have only been 4 wheels off one time. Today I was 4 wheels off twice. Brought the car around in turn three in the third session and drove all four wheels in the grass on the inside. No big deal as I was able to counter enough to drive straight on through to turn 4. Session four I went 4 wheels off in turn 4 and couldn't counter quick enough to keep me pointed in the right direction. Ended up with th back of my car pointed toward turn 5 bypass. Car stalled. Fired it up and got back on the track. The fastest guy getting timed in open class was driving a newer Z06 and at the end of the day he was only faster by .300 of a second. His name was Brian Lock. I'd seen his name on the NCRC site often when I'd take a look at track times and remembeed his name becaus he was always the fastest guy at least 90% of the time. Very cool guy and we talked for awhile. The new rear sway bar set up is doing its job. Car is feeling neutral again.
Thanks to Todd and his Healthy 101 thread I feel great. Still have a ton of energy. I'm amazed.
I'll start loading photos and see if I got anything out of the Go Pro as it was acting up.
Now we have to sit and determine if the sway bar change induced snap over steer or if your tires just weren't working with the track. I predicted that you would have to tune for neutrality and just not tight.
Old 06-30-2013, 07:39 PM
Track Junky's Avatar
Clamp worked fine but we need to make two changes. We'll talk later.
Gaetano Cosentino
Old 06-30-2013, 07:54 PM
don't tell me:
make it in AL
replace the allen button heads with longer 6 point ARP's
lengthen the chromoly rods by 1.250 in
increase the bar length by 2" on each side.
Old 06-30-2013, 08:02 PM
don't tell me:
make it in AL
Well since your going there:
keep it steel
We need to narrow it
Heim joint rod is hitting upper bracket when I max it out for length.
Gaetano Cosentino
Old 06-30-2013, 08:39 PM
keep it steel
i'll take a look at it when you are in for the accusump
Old 06-30-2013, 09:25 PM
Sorry guys, Go Pro vid is a fail so I'll just run through the day session by session. Most laps I got in each session were maybe 4-5 at the most. As soon as I new I wasn't going to turn a faster lap I came in to log info and make adjustments and let me add trying to tune on a slick track was no easy task.
Session one started out well. 1st and second lap felt fine in the corners. I was relaxed and taking the car in. She felt really smooth and neutral in the corners. I started to get on er a little harder the third lap and she started to feel real greasy. Hot tires slick track. 4th lap I was coming up on three real hard. I came in from the outside for a late apex with an early turn in anticipating the four wheel drift to nail the apex perfectly. 1/4 of the way in the back end came around and I caught her just in time to be able to drive straight through the dry grass with 4 off and continue through four. Time to bring er in. Only thing that made me nervous was the shuttering of the steering wheel heading down the straight. It had never done this before and I attribute it to the new alignment set up for now but I will be checking, bearings, brakes, etc. The new alignment went from 1.8 neg camber to 2.5 and I brought the toe in another 32th for 1/16 positive toe on each side.
Time to hit the sack. To be continued......
Gaetano Cosentino
Old 06-30-2013, 08:43 PM
keep it steel
how was the adjustments in the heat? easy?
Old 06-30-2013, 08:44 PM
Glad you had a good time Gae!
Just so ya know - I've always had all my wheels on the track even when I spun it in turn 9...
I can only imagine how greasy it was out there today. OMG.... Way too hot! The oil would have been oozing out it.
How hot were YOU??
