Old 07-01-2013, 12:15 AM
It was my first and I'll be back. Wish I could make it today even at the forecasted 93* to shoot more pics and practice with the video side of the camera.
Hopefully Dale's addicted and going back today to feed us more pics and video.
nice job with the vid but what place did your thumb come in?
Old 07-01-2013, 12:28 AM
Yeah great pics and write up Dale... thanks for sharing it all.
As much Ford trash as I talk, I don't care what car/manufacturer is your favorite, that Torino kicks ass.
Old 07-01-2013, 08:09 PM
DaleTx's Avatar
DaleTx DaleTx is offline
Originally Posted by MX145 View Post
I feel like I really missed something! These cars are unbelievable! PIR is about an hour and half away for me. Hopefully next year. I'm putting it on my calendar.
I live close by and never went either... It was better than expected, I'll be back next year to.
Originally Posted by compos mentis View Post
Dale,
Great job on the info and the pics.
I remember LeeRoy.
Thanks Skip... heck of a driver.
At least I got my thumb out of the way by the time the Torino finally went by...
I agree... seriously it was great to see it out there running
Check out the difference in front spoiler size between the two gen 1 Historic Z28's out at the race this weekend.
Much more area on this guys spoiler. This is the car running 155+ mph's on the straights.
This looks like a stock spoiler on this one
More pics of another gen 1 Z28 at the race.
Intersting cold air intake on the cross ram set up.
Looks like the GW CAT-5 leafs
Custom air duct for cooling the front brakes
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
Old 07-02-2013, 07:01 AM
clill's Avatar
clill clill is offline
Originally Posted by DaleTx View Post
I went to the historic races at PIR today and bumped into Sieg We spent some time talking to the mechanic and driver of this nice 1967 Z28.
This car won it's class by almost a full lap running against mostly Corvettes and Mustangs. This car was way faster than the other cars...the driver was on the edge at all times. The mechanic told me the engine runs up over 9K. It had a 4:56 rear axle and he went 155 mph down the main straight. I do have a video clip of it running wide open that I will post up later.
Dry sump tank in the trunk and a fuel cell...
I thought of Dave (Flash68) when I saw these side pipes... very cool...This car sounded amazing going down the straight!
Jerico 4 speed transmission
302 pumped to the hilt. The driver said it had over 500HP but would not give us the actual number. 5 stage dry sump pump, step headers, titanium valves, Holley carb.
I really liked this picture.
Am I the only guy that thinks it looks more like a 68 ?
Old 07-02-2013, 07:16 AM
Track Junky's Avatar
Other than it missing the wing window up front what would seperate em?
Gaetano Cosentino
Old 07-02-2013, 07:19 AM
fleet's Avatar
fleet fleet is online now
Different parking lights etc.
Old 07-02-2013, 08:11 AM
DaleTx's Avatar
You are right... I did a search for the entries at the 2013 PIR Historic races and here is the listing for the car:
"Kunicki Dave Surrey BC Canada 1968 Chevrolet Camaro 5000cc 67 Red"
Like Skip showed in the pics, 67 round parking lights, 68 rectangular shaped parking lights.
Good eye!
Sorry about that.
Mario Andretti
Old 07-02-2013, 08:28 AM
Good catch Charlie
Gaetano Cosentino
Old 07-02-2013, 08:55 AM
Sieg's Avatar
Sieg Sieg is offline
Nope!
It's car number 67 which I believe lead to the confusion. I'd just about guarantee Kunicki (owner/driver) would have a humorous explanation as to why it's a '68 with #67.
If you get a chance to watch this car run do it! You'd really appreciate it.
Old 07-22-2013, 10:58 PM
DaleTx's Avatar
Default GW Cat-5 leaf spring install
Since installing my new 427” LS engine I have had some problems with my rear leaf springs wrapping and the car squatting under hard acceleration in the low gears. The leaf’s wrapped enough that I could feel a very slight drive-line vibration. I had to use wedges to change the pinion angle by 3 more degrees to eliminate the vibration problem. The car still handled good with the Hotchkis multi-leafs and rear sway bar set up… but I didn’t like the squat and the wrap.
My plan was to switch out the leaf springs and rear sway bar set up with a Quadra-link this winter. After getting some input from a couple guys on here, I decided to try the Global West Cat-5 road race leafs as a next step, rather than go to a Quadra-link.
The GW leafs have spherical bearing mounts on both ends, and a full floating, heavy duty shackle mount. When I called Global West they said the Cat-5 leafs were rated to handle up to 700HP. I bought the Cat-5’s with the reverse eye mount, so I could get the car as low as possible and not have to use a large spacer between the leaf and axle.
Cat-5 with reverse eye in the back and Hotchkis multi-leaf in front
The GW leafs have a spherical bearing mount at both ends vs a rubber bushing.
These GW springs were expensive, but well made
Close up of the spherical bearing and spacer
Spherical bearing with spacer removed
Here is a shot of the shackle and bushing set up with built in grease fitting
The blue anodized aluminum sleeve presses into the rear sub frame, and the white delrin bushing slides inside. The bushing fits very precise and does not allow for lateral movement of the shackle and leaf spring.
Installing the leaf in the car
Here is a shot of the front spring mount with the reverse eye set up on the leaf spring
I used a 3/4" thick spacer with a 3 degree angle between the leaf spring and axle to set the pinion angle
Cat-5 leafs installed with wedge spacer
Spring swap completed!
I have been driving the car with the new leafs for a couple of weeks now. Major improvement... the car does not squat on acceleration... hooks up much better... and feels way more stable in corners. I will be doing another track day in two weeks and I can't wait to try out the new set up.
Thanks again on the good advice guys.
Mario Andretti
