07-12-2013, 10:59 AM
Hey Rob,
I've calculated the wheel spring rate we need, but to tell you what spring rates to get, I'll need "True Spring Motion Ratios" that include spring angle from your chassis builder ... so get front & rear ... and post them.
We may be able to work with your existing rear sway bar, if the effective rate is high enough. Typically AME's have 3 positions. Get the effective rate in all 3 positions & post.
Might as well get & post the effective rates for the front sway bar too, but I doubt it will be high enough for the SS/BB set-up I'm going to recommend.
Ron Sutton Race Technology
07-12-2013, 12:25 PM
Rob,
What I have outlined below is a soft spring/big bar … high travel, low roll suspension setup that you & I discussed … to optimize the handling of your long wheelbase car with tires 21% larger in the rear.
It is just a baseline to start from ... and it assumes a lot of things for us to discuss & get clear on. Most of these assumptions can be tuned around, if my assumption is wrong. Some can not.
Assumptions:
3500# car
116" Wheelbase
51.5% front weight
19” CG height
2.5”-3” front shock travel in dive
Front track width 56” & rear 58” / 2” wider in rear
285 front tires & 345 rear tires / Same compound front & rear
Readers … do not run with this set-up for your car. That would be like taking someone else’s medicine when you have no idea what health issues they have. I can not say this strongly enough. This is not a universal set-up or even a universal concept. I have outlined this for Rob’s long wheelbase Torino with tires 21% larger in the rear & a 2” wider rear track width.
Baseline Starting Point to Tune From:
Springs & ARB's:
Front Wheel Rate: 275#
Front Spring Motion Ratio: _________?
Front Spring Rate: _________?
Front ARB Effective Rate: 1050#
Rear Wheel Rate: 350#
Rear Spring Motion Ratio: _________?
Rear Spring Rate: _________?
Rear ARB Effective Rate: 400#
ARB (Anti Roll Bar) Arms:
Front: Short, strong (4130 chromoly)
Rear: Steel, no aluminum
Front Roll Center: 4" at ride height & 1.25"-1.5" in dive
Rear Roll Center: 11” with level Panhard Bar at ride height
4-link Specs:
Lower Bars: 0.0 degrees / Level at ride height
Upper Bars: 9-10 degrees down in front
Instant Center: Same height as lower bars … 50-60” ahead of rear axle CL
Pinion angle: 2-3 degrees negative from the driveshaft*
Front Shocks:
I’m not willing to share my proprietary valving info on a Forum. In general, you will need moderate compression valving in the front, to slow the rate of compression on braking & corner entry & substantial rebound valving to hold the front end down through the corner.
Rear Shocks:
Again, I’m not willing to share my proprietary valving info on a Forum. In general, you will need moderate compression valving in the rear, to slow the rate of compression on & corner entry & moderate rebound valving to keep the rear tires planted on corner exit.
Adjustable Shocks:
Triple adjustable shocks ... low-speed rebound, hi-speed rebound & hi-speed compression ... are a key to dialing in a bad ass race car on track day ... and dialing it back to a drivable Pro Touring car at the end of the day. There are poor shocks, good shocks & great shocks available. I choose not to talk brands on a forum.
Wheel width:
Your 285’s need to be on wheels 1” wider than the tread width & put the rear tires on wheels with the same width at the tread width. You want the front tires “stable” and you want the rear tires to “move around” a little.
Tire pressures:
Optimized for full contact patch & even temps.
Rob, as with all cars that get pushed to their limits ... when you find the limits, you WILL NEED TO TUNE on this set-up. I’ve got you close … except for shock valving … which we’ll need to discuss.
In my next post, I’ll outline some tuning strategies after you run it on a road course. And if you want, we can discuss some changes for better AutoX performance.
07-12-2013, 10:38 PM
Originally Posted by Ron Sutton
Hey Rob,
Hey Ron. I just got home from running errands and goofing around at a buddys house. I'll take some measurements tomorrow and get some specs.
I went down to Speedway Engineering today to grab the proper drive plates, inner seals and dust caps.
I continue to be impressed with the Machine work done by Travis and crew at Formula 43. The drive hubs in the last pic are being held in place by the perfect interference fit of the hub to the wheel center. Hub centric magic at its best  Travis.
07-13-2013, 12:04 AM
07-13-2013, 04:22 AM
Man Rob your thread is just dripping with tech now, this is great!! It kinda drowns out all the BS  although I'm sure once you slow down on the tech and progress it will be full steam ahead!!
Rick
07-13-2013, 09:13 AM
Fun little road trip yesterday. Rob and I stopped at Speedway and we're like two kids in a candy store. Their finished parts warehouse was just so cool. Snouts, drive plates, dust covers, housings, crowned axles you name it.
I couldn't help but pick up and admire at least one of everything and you can see above the quality of finished products. And the people there are just great too.
I think Rob bought an extra drive plate to be made into a hip hop/car guy necklace
Dust cover and fit looks killer Rob.
07-13-2013, 10:02 AM
Wow, you are sure not cutting corners anywhere! I don't know how you sleep much at night, as all of this all comes together.
What is your projected completion date?
07-13-2013, 10:09 AM
Rob,
And anyone reading along with us …
The following helps explain each suspension set-up or tuning item in more detail.
The “Soft Front Spring/Big Sway Bar - High Travel/Low Roll” set-up loads the front tires more on corner entry & braking … and therefore unloads the rear tires more … than “Conventional Stiff Front Spring/Small Sway Bar – Low Travel/High Roll” set-ups.
An additional benefit of the front end compressing more & is it acts like stored energy on exit … allowing more front end lift travel under throttle, for increased load & grip on the rear tires.
Utilizing this strategy for this application is based on the need to:
a. Assist this long 116" wheelbase car to turn better.
b. Overcome a 21% larger rear tire bias.
Here are the keys to this modern suspension strategy & a few other tuning suggestions, all designed to take a car that would otherwise push … due to the long WB & 21% bigger rear tires … into a good turning road course track car.
1. The KPI/Caster Split favoring the caster … combined with a small amount of caster gain in dive … corrects the angle of both inside & outside wheels … to achieve a full contact patch with both front tires for optimum cornering ability … without running excessive static camber.
2. The “anti-dive” built into the A-arms helps prevent the soft front suspension from compressing too fast under braking. Plus provides the desired caster gain.
3. Achieving camber gain with the A-arm/spindle/ball joint geometry means we don’t need as much static camber. You want some static camber, as it loads the outside front tire instantly on turn-in … improving responsiveness. Just don’t get greedy, and run more camber & less caster. Caster helps both tires achieve the correct tire contact patch… and is progressive. Camber helps the outside tire angle & hurts the inside tire angle & is always doing it. I see some AutoX guys with 5-6 degrees of camber and during corners the inside front tire is using half the contact patch or less.
4. You want a little toe-out. Like static camber, static toe-out improves initial turn in responsiveness.
5. Get the rest of the “dynamic toe out” with Ackerman or bump steer. In race cars, it almost doesn’t matter which we use, because the suspension is always compressed in the corner when we’re turning. Ackerman is the preferred method in a PT car, so you get the benefit on the street too, when the suspension is not compressed. Regardless, you need the inside front tire turning at a tighter radius than the outside tire for optimum front tire grip. Otherwise, you’re dragging the inside tire, instead of the inside tire helping the car to turn.
6. The softer front springs allow the front end to travel farther on corner entry & braking. This varies by application, but the goal is 2”+ instead of ¾”-1” of a conventional set-up. This loads the front tires more, giving them more grip & providing better turning ability.
7. The huge front ARB, plus stiffer rear springs & stiffer than most rear ARB … all work together to keep the car at a low roll angle. This keeps the inside front tire engaged more than a high roll set-up. It also unloads the rear tires more evenly.
8. The stiffer, stronger (and shorter if possible) ARB Arms … load the tires quicker … and make the car more responsive. You will need this in a big, wide, 116” wb car.
9. The front roll center at 1.25"-1.5" “in dive” seems low, but is actually a little high … which is best for loading the front tires on road courses. If you were AutoXing, we would run it around 0” in dive.
10. The rear panhard bar at 11” is high … only to free up the load & grip on the 345 rear tires … and to help the suspension keep the inside front tire loaded during cornering. This will be one of the first things you should tune on at the road course track. If the car is loose, you will lower it. If yours is not infinitely tunable … correct this. Having a non-adjustable panhard bar in a handling car is ridiculous.
11. The 4-link specs I provided will provide more traction on exit and frankly assist with weight transfer from the rear tires to front tires on corner entry. This needs to be tuned to find the happy balance. If you increase the downward angle of the top link, you will add “initial” grip to the rear tires on corner exit as you pick up the throttle … AND it will transfer more weight from the rear end to the front end, as the rear lifts under braking. If you go too far … in search of exit grip … you will make the car loose on entry.
12. The lower bars of the 4-link (3-links too) control “rear steer” or “roll steer”. If you run the bars level at ride height … or 0.0 degrees … as the car rolls over in a corner … both bars pull the rear end forward the same amount, so the rear end stays “true” to the chassis. If you raise the front of the bars (at the chassis mount) or lower the rear (at the rear end housing) you get rear steer … meaning the outside tire is pushed back & the inside tire is pulled forward. This helps steer the car from the rear a little like the fork lift concept.
More angle is more rear steer. Going down in the front or up in the rear, acts in the opposite way, pushing the outside tire forward & the inside tire is pushed back, which does the opposite, causing the car to “tighten” as it is being steering to the outside of the corner. Rear steer affects the exit too, because the car is still rolled over to a degree. So I use rear steer as a tuning tool to free up the car when it is tight or pushy mid-corner & exit.
13. Again, I’m not willing to share my proprietary valving info on a Forum, but you need front shocks valved to have the front end compress at a nice, controlled, smooth rate … and keep the front end down through the middle of the corner, after you have lifted off the brakes … and release & let the front lift as you roll on the throttle.
14. Having front wheels wider than the tread width will improve both initial turn-in responsiveness & front tire grip. Having the rear wheels equal to the tread width will help free up the car on entry & middle & help grip up the car on exit.
Make sense? Got questions?
Everyone feel free to chime in if you have relevant conversation.
07-13-2013, 12:57 PM
And then the fight broke out  If I put it in print it will come back to haunt me. It will hit the road and track in shakedown mode. No new paint no finished interior just bare bones first to sort some things out. I will say that will happen within six months.
Kenny & Joanne are great people with great product. We run a ton of their stuff. Love 'em.
Yes they are a pleasure to deal with. No need to go anywhere else if you are looking for real, usable, durable and beautifully made parts.
Originally Posted by gmtech921
I have a car I wanted to build and knew in building it I had to overcome some obstacles. The biggest is my desire for the car to still be a Torino and not some hacked up rendition of one. Nobody take that wrong. Even the pedigreed race Torino dale posted is hacked up. Look at the wheel wells they just cut a big opening to clear the big wide tire for the front. A car can look very cool hacked if hacked properly that just wasn't my goal for this car. So the technical discussion of how to fit 10lbs of suspension in a 5lbs box is a great one that I am really enjoying, and learning, from.
Rob,
Ron I am digesting. I sent you some more info and some more thoughts.
Your point on rim width was one I was getting at when this stared. I felt first I needed to determine the widest wheel I could fit on the front and then size the tire. I came up with the 18x10.5" wheel within my body, frame, suspension limitations. My feeling was the 285 35 18 on that wheel was a better fit than a 295 or 305 because of the slight stretch. I believe I was thinking along the lines you are stating. Correct me if I'm wrong.
- The stretched tire would actually have as big or larger effective contact patch due to teh treads flatter profile at the same pressure.
- The stretched tire would allow me to run more tire pressure allowing for more laod capacity while still maintaing the contact patch over a larger tire on teh same width wheel.
- The stretched tire would stiffen the sidewall (screwing up my ride) but improving the tires turn in and holding power.
To maintain my aesthetic goal of no flares the 10.5" wheel was my max. I can run a larger tire on that wheel but my feeling was the one I chose was the best fit for my car.
07-13-2013, 10:12 AM
| Thread Tools |
| Display Modes |
Hybrid Mode
