07-09-2013, 10:20 AM
Mast M-90/M-120 vs. GM ECM
Hello Guys, I'm in the planning stages of an LS swap (525hp LS3) and just wondering if you have any experience with the MAST ECM compared to the stock GM ECM? I'm thinking it will provide better tuning options for HP upgrades over the GM ECM. Not sure if the +$800 - $1000 is worth it for the Mast unit over the GM one.
Josh
Designing a '65 Chevelle with a StreetFighter theme, inspired by JP's II Much & Ron Schwarz's $5k Mustang
07-13-2013, 10:11 AM
I use the Mast M90 on my personal car (LS7). I've also tuned a lot of GM ECMs on late models and retrofits.
As to what is "better", it depends. From my personal perspective, I won't use an ECU which doesn't support knock sensing/control, and both of these support it. Both also support drive by wire throttle, if that's what you want. To oversimplify a bit, the biggest difference at a high level is that the GM ECU runs open loop at wide open throttle, relying on the MAF sensor to account for airflow variations. The Mast runs closed-loop all the time, using a wide-band O2 sensor. Wide band closed loop is the optimal strategy for a performance motor, IMO, because it can account for variations that a MAF sensor can't, like the oxygenation of the fuel. But in practice, both can work well in performance applications if carefully tuned.
On that careful tuning part: some ups and downs to both. The Mast is much simpler in terms of the number of tables and interactions you have to deal with, but the (free) tuning software lacks convenience features like table smoothing and interpolation. That makes data entry for fuel and spark tables quite tedious. The GM ECU must be tuned with a package like HPTuners, EFI Live, or SCT Advantage. All of these packages are significant extra cost ($700+) if you obtain them yourself; otherwise you rely on a professional tuning shop, which is recommended in any case if you're not up on EFI tuning. The GM ECUs have a significant learning curve to tune correctly, more so than the aftermarket alternatives.
Another alternative to consider is the latest Holley HP or Dominator EFI system. I've not had any experience with these on LSx motors, but have tuned a couple of retrofit systems using the HP ECU recently. It's a very nice combo of ECU and software.
I'd give you a brief warning about cost assumptions. Depending on your exact combo, by the time you get everything necessary to make each ECU work, the cost differential can end up lower than you might imagine.
All this said, unless you're planning to change cams on your crate motor, I'd personally probably lean to the GM ECU package. Make sure you get it tuned, though - I've tuned three GM crate motors with retrofit ECU package, and each of them was fairly far out of tune, particularly the MAF transfer function.
07-13-2013, 11:17 AM
^ great post Addict!
07-13-2013, 12:35 PM
Question to PTaddict, do you know how far out the gm performance crate motors ECU's are? I have the ls3/525 going into my chevelle and am wondering how much more there could be in it. Have you done any of those set ups yet?
Excuse me if I am hijacking this thread, maybe a P.M. would be better let me know. Thanks.
07-13-2013, 01:29 PM
I've only done an LS2 and two of the 480 HP LS3s. But it's not really possible to answer your question specifically in any case.
Some background. The GM ECU uses a Mass Air Flow sensor to determine how much air the engine is taking in, and therefore how much fuel to inject to achieve the desired air/fuel ratio. But the thing with a MAF sensor is that it will read quite differently depending on the inlet tract in front and behind it. Change the inlet plumbing, and the MAF sensor will read more or less airflow at different points in the RPM band. If the MAF reads lower than the actual airflow, you end up with a lean condition. (Incidentally, aftermarket air inlets on late model cars nearly always cause the MAF sensor to read less airflow, thereby leaning out the engine at WOT. Some of the HP gains attributed to aftermarket air boxes are almost certainly due to this leaning effect).
GM gives some fairly specific instructions for how the MAF is to be plumbed into an intake tract, but still they can't know the exact configuration. So they program the MAF transfer function to read high, so that if you have a sub-optimal inlet tract, you won't end up too lean (at least, that is my speculation based on what I'm seeing). But if you do have a close to optimal installation, you now end up too rich. On one of the LS3s I tuned, the fuel trims were stuck full lean and the engine was still blubbering on at about 12:1 at idle. The only way to fix this is to retune the MAF transfer function, which fortunately is one of the easier things to tune if you have the right tools (software, wideband O2 meter, chassis dyno).
Anyway, that's why I'd recommend a tune for any retrofit with GM ECU. Hope that all makes sense.
07-13-2013, 02:25 PM
Thank you it does make sense. You gave me some clarification. I need to find a tuner in my area (or in the car's area since it is at a shop) to do this at some point after its completion. I appreciate the information.
07-15-2013, 05:01 AM
Great info!
I just want to add the gm ecu can be set up to run a custom OS in a speed density mode, not using the MAF. The car can be dialed in using a wide band and run well on its narrow band O2's. There are tuners who have perfected this and I imagine it helps when running heavily modified engines. My cammed N/A ls7 with an e38 is setup this way, I believe it also uses a 2.5bar map.
Rich
07-15-2013, 08:39 AM
Originally Posted by 67ragtp
Great info!
Rich
Yes, I've tuned a couple of cars this way when MAF was not an option for one reason or another. It doesn't actually require a custom tune to do so, although sometimes a custom tune that supports real-time updating can shorten the tuning time. But personally, I prefer not to use OLSD tuning - open loop speed density - unless there is no other option.
Some explanation for EFI novices: there are two strategies to determine how much air mass an engine is ingesting, and therefore how much fuel to supply. (Actually there's a third called Alpha/N, which we won't get into). A Mass Airflow Sensor directly measures air mass into the engine. Speed density depends on the ECU to predict how much air mass an engine is taking in at a given time, using RPM, Manifold Air Pressure, and Intake Air Temp as primary inputs - speed = RPM, density = functionof(MAP,IAT), hence speed/density. From there, the tuner models the engine's breathing (volumetric efficiency) throughout the RPM and MAP operating range.
OEM applications almost all use MAF as the primary strategy, augmenting with speed density for transient cases. Aftermarket systems almost all use speed density. But almost all aftermarket systems also use wideband O2 sensors and run closed-loop all the time, thereby providing an automatic correction - a safety net - for any minor errors in the speed/density prediction. That's important from my perspective, because truly accurate predictive modeling of air mass is quite challenging.
For instance, the IAT sensor is typically placed upstream of the throttle body. By the time air reaches the cylinder, it will have been warmed somewhat by the intake manifold. How much it gets warmed will depend on the manifold temperature, which in turn depends on the underhood configuration, and how much airflow is passing over the intake. So the OEM GM applications actually have a complex configuration-specific function which adjusts the predicted airmass by up to several percent based upon the car's recent history of road speed! It boggles the mind how much work must go into creating a factory tune.
So I personally prefer to use tuning strategies which account for conditions outside the day on the chassis dyno. In practice, though, tuners tend to be smart, opinionated people who get results in a number of ways  And OLSD tuning certainly gets used successfully. After all, carburetors can be thought of as crude OLSD devices with bad temperature compensation  and those have worked OK for a hundred years or so.
07-15-2013, 09:40 AM
Im in the novice territory with regards to understanding EFI, and trying to understand the technicalities. Im fairly certain that my speed density tune runs closed loop with the short term fuel trims active for idle/cruise normal driving and open loop during WOT relying on Volumetric efficiency tables and PE table. This stuff gets pretty complex, throw in HP tuners
Thanks for the info- Rich
07-15-2013, 01:44 PM
Yup, you have it right, SD tunes typically run open loop only during PE mode (higher load). And yeah, factory ECUs are very sophisticated and complex now, and that complexity all comes through in the tuning software. Your garden-variety ECU would have been considered a supercomputer 20 years ago.
Thread Tools |
Display Modes |
Linear Mode
