Closed Thread
Old 07-20-2013, 06:05 PM
Ron Sutton's Avatar
Ron you are the BOMB!! Cant thank you enough for sharing this info. I'm going to have to spend some time confirming my prior notions but I'm pretty sure if I drop the front of my car another inch I should be able to achieve the dynamic camber I am looking for through my control arms without putting so much static camber into it. I'll be testing at T-Hill on August 11th so I'll keep you posted.
Cool.
If you need any guidance, just drop me a PM.
Ron Sutton Race Technology
  #1362
Old 07-20-2013, 08:15 PM
glassman's Avatar
glassman glassman is offline
ummmm, that is some good info right there, can that be stickied in the suspension section?
Other wise i might have to keep comin back to this Ford thread...JK
  #1363
Old 07-20-2013, 08:27 PM
Ron Sutton's Avatar
This coming week, we're going to start some specific forums on chassis tuning topics that will be "stickied" from the start. They will be very in-depth & detailed but general in nature for all PT cars.
  #1364
Old 07-20-2013, 10:07 PM
FETorino's Avatar
FETorino FETorino is offline
I just catching up on some light reading before I dove into Ron's posts.
Rob in SoCal
  #1365
Old 07-21-2013, 12:01 AM
Ron Sutton's Avatar
That is cool Rob.
Love the old stuff.
  #1366
Old 07-21-2013, 02:24 AM
fleet's Avatar
fleet fleet is offline
Originally Posted by Ron Sutton View Post
That is cool Rob.
Love the old stuff.
X2.
Now how about posting some of your vintage '68 Camaro pics?
Old 07-21-2013, 09:15 AM
FETorino's Avatar
Originally Posted by compos mentis View Post
X2.
Thanks for asking
Here are a few of my favorites.
Aren't you glad you asked.
Rob in SoCal
  #1368
Old 07-21-2013, 09:45 AM
fleet's Avatar
Thanks for asking
I forgot who I was dealing with.
So Rob, aka 'Big Butt Torino guy' FTW.
Old 07-21-2013, 09:53 AM
Sieg's Avatar
Sieg Sieg is offline
'Bout time we saw something with potential in this thread.
  #1370
Old 07-21-2013, 10:03 AM
FETorino's Avatar
Some people like to look at the car as a unit. I look at it as two halves. Here are some examples … using a typical 3500# Pro Touring Car with 53% front weight… to provide more clarity:
Tuning with Rear Roll Centers:
This limited tunability of the Watt’s link requires the tuner to rely more on other tuning items such as springs, shocks & sway bars. It reminds me a little of torque arm suspensions. They work well, just not much tuning adjustment. I think they’re the ticket for car guys that want to get a good set-up & just drive it.
As a tuner, I like to have a full tuning “tool box” at my disposal, and a panhard bar (or track bar, depending on where you came from) is more tunable. With the right adjustable mounts, I can move the RC 1/16” if I wish. I can make it super low … super high … or anywhere in between.
Direction … regardless if you’re using a Watt’s link or panhard bar:
a. Raising the RC, places it closer to the CG, reducing the CG leverage, reducing roll angle … and working the rear tires less.
b. Lowering the RC, places it farther from the CG, increasing the CG leverage, increasing roll angle … and working the rear tires more.
c. With low roll suspensions utilizing mean stiff rear springs … or medium springs & significant rear sway bar … for faster corners found at big road courses I’ve found the happy window to be 9” to 12” … and 7” to 10” for tight AutoX events.
d. Softer sprung, higher roll rear suspensions run higher rear RC’s.
*KEY NOTE: For optimum cornering ability, you need to position the rear RC low enough to work the rear tires … allowing just enough rear roll angle to disengage the inside rear tire to a degree … but high enough to prevent the outside rear tire to roll over so much that the car rolls diagonally … and unloads the inside front tire.
Ron
Starting with the first statement about looking at the car in two halves. Correct me if I am wrong but I'm assuming you are speaking about the need to tune each end of the cars roll resistance based on each ends independent RC and not that the effect at one end is independent of the other end of the car.
A well built car should have a stiff chassis that allows the suspension to do it's work without the added variable of the frame flexing. But that stiff frame translates load from one end to the other.
Looking at you diagram of roll axis it seems obvious that increasing the length of the moment arm at either end would introduce some additional roll at the opposite end as the frame resists twisting.
If that line was a piece of pipe running through the car as I twisted one end clockwise the other end would follow in a clockwise direction.
Is it the front that unloads the inner rear tire on corner entry and loads it on corner exit?
If the balance is correct, would work something like.
The front have enough roll resistance going into the corner to keep the front flat and load both tires.
The rear also have the amount needed to keep it flat as the front first turns in.
The front roll translated through the axis provides enough added force to unload the inner rear tire which helps prevent overloading the outside front tire.
As you unwind the front on exit and that translated roll force diminishes the inner rear tire in again loaded for better corner exit.
In you statement about tuning the rear I think what you are doing is tuning the rear so that is have just enough of a moment arm to be overcome by the force from the front but not so much where it is overloading the front.
I'll wait on the answer to this to ensure I fully understand it before I ask what effect wheelbase would have on this relationship.
Let me go find my hat I may be wearing it soon.
Rob in SoCal
Closed Thread
