Old 07-30-2013, 06:31 AM
Evan Iroc-Z Evan Iroc-Z is offline
What an incredible build! I cannot wait to see the packaging of everything under the hood.
'89 IROC-Z Turbo 3.8 5SPD
LS1 Brakes|Wilwood Prop Valve|LS1 Master Cylinder|Aluminum Driveshaft|LS1 3.42 Rearend|Adj PHB|Adj LCA|LCARB|Koni Struts|Koni Shocks|Adj Caster/Camber Plates|STB|10 Spoke SS Wheels|PHB Relo Kit|Adj TA|SFC|ARAP Based Prom|B&M Short Shifter|Underdrive Pullies|SMOG!|AIR!|Rag Joint!|Magnaflow|Ported Plenum|Misc Stuff
Old 07-30-2013, 07:23 AM
mfain mfain is offline
Here is a picture of the initial LS fitting. No issues with it waaaay back!
Here is the way brother (Robert) found the car --- in the barn in the background for 32 years, 265 inch motor sitting between the framerails, and a picture of early disassembly that got him kicked out of the local Jaguar club. LOL
Size:  81.0 KBName:  IMG_1547.jpg
Size:  45.3 KBName:  IMG_0142.jpg
Old 07-30-2013, 10:54 AM
Fitz78ta Fitz78ta is offline
boy that will get the purists talking!
I, like everyone else, LOVE IT! Probably won't ever see another one like it for sure.
Project:
1978 Trans Am - Twin turbo Iron block 370 LS1
All fabrication done by 417 Motorsports
https://lateral-g.net/forums/showthread.php4?t=30588
Old 07-30-2013, 12:39 PM
preston preston is offline
Did he build the frame or was it sourced somewhere ? Looks aftermarket as most home builders don't venture outside of the 2*3 tubing but either way it looks like a nice setup, but even on a 2700 lb car I recommend power steering (easy enough to convert that rack as long as you leave room).
Old 07-30-2013, 12:48 PM
Believe it or not, the frame is actually the Jag frame, heavily modified by Robert. He built the front cross-member and the rear kick-ups and IRS mounting provisions. As for the power steering, Robert informs me that I lied. The weight, with everything stacked on the car on scales, is closer to 2100#. Tony Woodward felt that would be light enough for manual steering.
Pappy
Old 07-31-2013, 06:01 AM
Attachment 41110
Does he know what accessories he is going to be running. The slope on the front of the hood makes me think it is going to have to be almost 100% custom.
I also love the fact he was kicked out of the Jaguar club. That is hilarious.
Old 08-02-2013, 01:01 PM
Custom brackets for an alternator, and perhaps a dry sump pump down the road. A little off subject, but he is pretty good at stuffing lots of Chevy muscle in tight spaces.
Like a 434 inch small block, injected on alcohol in an Anglia
Or a small block with air and power windows and upgraded suspension in a Citreon
Okay, not so small, but an 8.1 liter big block with vintage air, leather air ride seats, upgraded front independant suspenion -- in an old Ford cabover - pro-touring tow truck?
Old 08-02-2013, 05:01 PM
Very nice stuff.
Old 12-07-2013, 12:46 PM
Love it Papp
Old 12-07-2013, 04:37 PM
DETON8R's Avatar
DETON8R DETON8R is offline
That is just plane AWESOME!!
2,100 lbs, that thing is going to be a rocket!!
How wide are the tires in the back?
And the spacing between the rear hubs?
Is the late model Camaro IRS narrowed? If so it looks like you will need shortened half-shafts.
I'm asking because my next project is a Volvo P1800S.
I love to see what others are doing for ideas.
Keep the photos coming.
DETONATOR - 69 Camaro RS
