Old 07-14-2013, 08:16 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
Thanks, guys. I need to learn how to gas weld so the next time I do sheet metal it will come out even better (and get a planishing hammer, and an english wheel, and a shop to put it all in....)
Got a little bit done this weekend- I put some of that foam insulation inside my doors. It helps take the "tinny" sound out, and unlike dynamat it's really light, and some seam sealer along the bottom edge, and hung them on the car. I had to drill out and tap the door mounts on the bottom to the next size up as they were stripped out. I also put the rear bumper on, but it's not quite aligned yet. I'll need to mess around with that, after I take the clamps off the trunk weatherstripping. It didn't seat well so I'm taking a different approach this time.
Long Live the Muscle Car
https://lateral-g.net/forums/showthread.php4?t=26338
Instagram: @tuske427
Old 07-14-2013, 08:23 PM
Ron in SoCal's Avatar
It's coming together ya big stud
Ron in SoCal
69 Camaro in progress
Old 07-28-2013, 09:59 PM
Tuske427's Avatar
OK, had a little time yesterday and today. Just a few little things. First off- I decided to experiment with that tinted paint to see how it would look darkening the taillight lens. I had an extra lens that became the sacrificial tester. I painted half on the outside, and the other half on the inside, and it's sitting next to a stock piece. I'm quite happy with the paint on the inside, so I'll end up doing that. I'll be using LED lights so heat won't be an issue.
I also spatter painted the trunk, and installed the trunk latch. All I had to do was shorten the rod that connected to the lock cylinder, and I was good to go (the result of recessing my tail panel required modification to the lock system)
I also cleaned and polished the roof rail weatherstripping pieces, as well as the interior trim pieces. I had built my roll cage so close to the body that I was not able to install the trim in the rear area- so I had to grind back a section for it to clear.
While working on my car I discovered a spider web in the interior- guess I'm not working on my car fast enough..
I also got the door handles out and put the push buttons in rust dissolver to get rust off the spring and shaft- only to have one of my buttons crumble apart. I need an new one. anyone have any extras they don't need?
Old 07-29-2013, 09:43 AM
Looking good!
Old 08-04-2013, 07:08 PM
Tuske427's Avatar
Thanks, Wayne!!
This weekend I got a little progress in as well- I installed the roof rail weatherstripping, those screws around the window frames to replace the broken trim attachment studs, took the car off the body dolly onto some jack stands and installed the rear axle.
The body dolly isn't really suited for the weight of the entire car, so it had to go...
Old 08-04-2013, 07:28 PM
When I had the car done he put the weld on clip holders. I knew with my fat fingers it would be a disaster trying to use those little screws. Nice progress.
Old 08-05-2013, 08:26 PM
Tuske427's Avatar
Thanks, Wayne. Not to worry- my fat fingers flung them on the ground a few times myself...
Old 08-05-2013, 11:33 PM
MX145 MX145 is offline
Looks good Brendon. The trunk turned out nice. The cross brace between the 4-link mounts is awesome!
Old 08-11-2013, 05:03 PM
Tuske427's Avatar
Thanks, Ryan! I still need to build the bottom half of it- a driveshaft safety loop.
Old 08-11-2013, 05:15 PM
Tuske427's Avatar
Default Engine update
I picked up my engine this weekend from Superior. They built a 383 stroker out of my LS1. They also broke it in and made an initial run on the dyno with a basic tune. once the car is fully driving and has a few thousand miles on it then they will do a final tune. Now I just need to get the car together...
