Old 07-31-2013, 01:19 PM
Code510's Avatar
Code510 Code510 is offline
Looks like how you've built the frame and sheet metal that the bottom side of the car should be pretty much smooth then? Just maybe some exhaust and that's it? I saw this done on one other Chevelle years ago. It was pretty slick!
Old 08-01-2013, 06:11 AM
Charlesincharge Charlesincharge is offline
Code 510, your correct. the rockers roll down under the car and meet the belly pans. the underside is smooth.
70 GTO 400 Pontiac with fuel injection and a Procharger
65 GTO Art Morrison Max G chassis LS Power
04 M3 Convertible Daily driver
09 Avalanche LTZ 6.0L
74 Pantera GTS (Project waiting)
56 Nomad with LS power- SOLD
67 Fastback project SOLD
Old 08-01-2013, 04:21 PM
67goatman455 67goatman455 is offline
have any more pics/ info on the pedal mounting?
1967 GTO, LS2 T56
WILWOOD FORGELINE RIDETECH
$10k Budget driver/ track car
Old 08-06-2013, 11:43 AM
Here are a few. Nothing is 100% decided or finished yet. The firewall is back some (3") so the pedals had to come back as well. Right now I like the position and the feel. The factory parking brake assembly was shortened and moved closer to the kick panel. I don't have a gas pedal yet since I don't know if I'll use a cable or drive by wire.
Old 08-06-2013, 11:51 AM
Opp's, Pics didnt load. Resized...
Old 08-06-2013, 11:53 AM
one more
Old 08-07-2013, 02:56 PM
wookham's Avatar
wookham wookham is offline
Hey Charles
it looks like you changed the angle of the firewall, how far did you set the motor back??
Old 08-07-2013, 04:14 PM
good work on the pedals. gives me a little bit of a look into it before i start messing with mine, any reason you didn't go with the forward facing master cylinders? looks like it would have bolted up to the firewall nicely
1967 GTO, LS2 T56
Old 05-05-2014, 09:05 PM
1968 GTO Resto-Mod's Avatar
1968 GTO Resto-Mod 1968 GTO Resto-Mod is offline
hi charles,
this is such a cool project you've got going!
any updates?
cheers,
danny
Old 05-24-2014, 02:43 AM
brut4s's Avatar
brut4s brut4s is offline
WOW!!! MAD SKILLS!!! Any updates?
