Old 08-10-2013, 11:01 PM
MX145 MX145 is offline
Can't wait to see what she does. Hearing these motors fire up always gets my blood pumping. Never gets old! Your motor looks awesome btw!!
Old 08-10-2013, 11:09 PM
Dave your motor is bad a$$. Can't wait for the dyno numbers and vid
OT: Nice 69 in your sig! You think Big Red is running a factory spoiler @ 200 mph?
Thanks Ronnie.... Yeah, Big Red...can't go wrong there...
And Big Red can run whatever spoiler it wants. It can't not go fast.
Whats it going over to S&S for ? i thought you were assembled and ready to go, no?
They are a top notch machine shop for as far back as i can remember, my family lived in that hood for 40+ years. I dont know them personally, but they did the machine work on my engine for my boat through a machine shop.....
Do they dyno and tune?
Mike Blackstone (Watson Racing) has known Rick Santos (S&S) a very long and Rick is one of the few guys Mike trusts in the bay area. Mike has a dyno but because mine will run E85 he prefers to dyno it over at Rick's since his fuel system is more beefed up and set up for a lot of the alcohol motors they do over there. Makes no diff to me. I am in good hands.
Originally Posted by Ron Sutton View Post
Sure!
I need a few more details ...
Carb or EFI size in CFM
Compression ratio
Rod length 6.0" or ?
Are the heads SB2 or SB2.2
Are the cylinder head intake runners 286cc or different ?
Header primary diameter & length
Collector diameter & length
Cam degreed at ???
Is cam a roller or big lifter flat tappet?
Also: Is this a 4.4" or 4.5" bore center block & head combo?
If you don't have it all, just get me what you can.
Carb is Holley HP950, but as you know Ron, factory ratings (especially Holley) are not reliable with respect to cfm.
Compression is 13:1
6.0" rods
Heads are SB2.2 worked by Curtis Boggs @ RFD in Virginia. I am guessing you know of him or have heard of him. Peak is 410-420 cfm at .900 but around 395-400 at .700 closer to where my cam net lift ends up. Low and mid lift numbers are strong. The work done was intended for road race (vs the Nascar CNC programs) and not max hp at high rpm.
Header is stepped 1-3/4 to 1-7/8 to 2.... 3.5 collector. Do not have length. It is a Profab Nascar type take off I believe.
Do not know cam degree number.
Cam solid roller.
Block is Dart Little M -- not a Bowtie/SB2 block.... so that must make it 4.4" I am guessing.
Congrats on getting the engine ready for the dyno, Dave. Here's hoping you hit 800
Thank you! Me too.
Old 08-10-2013, 11:24 PM
FETorino's Avatar
FETorino FETorino is offline
That's great DG all you had to do was tell Ron look back at last Octobers posts for engine specs.
Any real updates?
Rob in SoCal
Old 08-10-2013, 11:45 PM
Ok.... wheels are finally done and on the car. I give you the Jongbloed Racing 330 wheel.... done locally in Morgan Hill.
18x12 front and 18x13 rear on 315 and 335 Hoosier A6's.
And the car is one the ground off the lift for the first time in probably 6 months. That's always a step forward.
Old 08-10-2013, 11:46 PM
Rich has been working on the fuel cell cage and I am really happy with how it's turning out. Just needs some top bars/straps and powdercoating. I gave Rich the "blueprints" for the cage found in Circle Track magazine. It uses about 50 feet of 1x1 square tubing. Heavy and a little overkill but about as safe as I can get I figure.
http://www.circletrack.com/safety/ct...d/viewall.html
Old 08-10-2013, 11:58 PM
Any real updates?
Nice avatar...
Old 08-11-2013, 12:00 AM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
And I thought the front of my car had stupid amounts of camber when I was looking at it the other day. BMF looks nothing but serious business now. And those wheels... I kind of really want some now.
Old 08-11-2013, 12:06 AM
Well this is only 2.5* actually, which is what Jake specs for my setup. I don't consider that too extreme. But maybe that's part of my problem... since I don't consider this car too extreme.
Old 08-11-2013, 12:20 AM
FETorino's Avatar
Matt Are you sure you can accept that hellafflush 315 on a 12" wheel up front.
Rob in SoCal
