Old 08-11-2013, 07:32 AM
Did you BENCH BLEED the master before installation? This is a must do step!
When the car is "cold" -- have you looked (removing the wheels - getting it up on stands or a lift - maybe the night before so you don't have to touch the brakes) at the spacing of the pads? Pad knock-back can act like this -- where the pads retract or get pushed back - and the first pedal action is just moving the pads back near the rotor.... This is usually something that happens when on a track due to deflection of the rotor pushing the pads back too far... but since we're just guessing here -- I'm tossing this out there.
Have you bled the brakes using the gravity method? Or?
Have you put a bunch of pressure on the pedal and just held there for a minute or so to see if there is a change or drop in the pedal?
Old 08-11-2013, 03:27 PM
usa-69z usa-69z is offline
Greg , to answer those questions,, i have vacuum bled , reverse bled and old school 2 man bleed these brakes to get 'pedal'. As far as a bench bleed , i did do this 'on car' by levelling the master out and bleeding as on a bench but while attached.. all seemed air free and got me half a pedal of pressure..I made adjustments and i can only get an inch from the floor before some sort of braking happens , but not at all safe. The only thing i have failed to do is wind up the rear calipers from new for the emergency brake. Obviously that will play a big part ive now come to realize.
within half a mile the pedal is like a rock and trying to stop the car and all four discs are almost on fire..Its been a fun exercise so far.
69 CAMARO - RIGHT HAND DRIVE AUSSIE MODEL.
383 SBC 8 STACK INJECTED EFI.
RIDETECH FOUR LINK REAR - DSE MINI TUBS .
SPEEDTECH FRONT A ARMS & COILOVERS.
MOSER 3.7 REAR- 6 SPEED T56 TREMEC.
FIKSE RIMS ETC ETC..
