Closed Thread
Old 08-10-2013, 03:54 AM
Sieg's Avatar
Sieg Sieg is offline
Originally Posted by DFRESH View Post
I'm pretty sure we need a photo of that in this thread for a visual.
DF
Couldn't find a herrafrush Torino
  #1442
Old 08-10-2013, 10:00 PM
FETorino's Avatar
FETorino FETorino is offline
Originally Posted by 67goatman455 View Post
you guys aren't saying it right.
It's Herrafrush
you have to talk Asian
: bad taste
Originally Posted by Ron Sutton View Post
How did that pump look internally?
Well good and bad?
These pumps are elegant in their simplicity.
This is the optional side pickup manifold is what I think they call it. It has two long studs and one small allen bolt that attaches it to the pump housing and two small o-rings around the fuel passages.
The housing is machined out of AL and hard anodized. The drive shaft and the secondary shaft ride in 4 small roller bearings. One on each half of the housing.
The good is my housing looks great. Clean with no pitting or corrosion to be found. The pump gears are shimmed on the shaft, I presume to obtain spot on operating height within the two steel plates that surround them within the housing. There the gears in the shim stack have a small amount of vertical play on the shafts but don't rock or move horizontally on the shafts. So I assume they are within operating tolerances and normal.
Now some bad
The main shaft has some bluing where it rides in the bearing. The bearing also has a roller or two with a faint coloring to them. So it appears I have one of four bearing bad in the housing.
Scratching the shaft with my fingernail (yes JerDog my manicurist would be horrified ) I don't feel any scoring and no pitting is evident. I checked the shaft with a mic and there isn't any difference in Dia so I'm pretty sure just a bearing swap and I'm in business.
I think
Rob in SoCal
  #1443
Old 08-10-2013, 10:16 PM
Dude that pump is neat-o. Definitely pro tracking.. I mean Pro Touring.
Would be very cool if you decided to run it.
  #1444
Old 08-11-2013, 08:46 AM
MX145 MX145 is offline
Wow! That is a niece piece!
  #1445
Old 08-11-2013, 09:38 AM
Ron Sutton's Avatar
Well good and bad?
Yes, part of what makes them so durable.
That's the key. Everything else is replacable.
Now some bad
I think
Yes. New bearings & lube. Micro polish those shafts & put it back together.
I PM'd you about the bearings, but now that I see the photos, our Waterman pumps are different. So ignore that message.
Ron Sutton Race Technology
  #1446
Old 08-15-2013, 07:15 PM
FETorino's Avatar
So I gave Waterman call. I can send the pump to them and they will rebuild and flow it for $110 + parts which a set of 4 bearings runs $54.
$40 for the pump + $110 + $54 = $204 for a fresh fuel pump ready to run. WTH I'm in, I bought a cable.
I just need the adapter plate for the back of the PS pump and I'm set. actually I need to start shopping for a PS pump.
Rob in SoCal
  #1447
Old 08-15-2013, 07:48 PM
Ron Sutton's Avatar
Cool. Good move. Did you talk to Allan ?
  #1448
Old 08-15-2013, 08:08 PM
FETorino's Avatar
Yes sir I did.
Rob in SoCal
  #1449
Old 08-15-2013, 08:11 PM
Rick D's Avatar
Rick D Rick D is offline
Man this thread is getting way to high tech for me! Rob I thought you were just building a Ford??
Rick
  #1450
Old 08-17-2013, 10:14 PM
Closed Thread
