Old 08-19-2013, 03:30 PM
JMitch19's Avatar
JMitch19 JMitch19 is offline
Originally Posted by parsonsj View Post
Excellent! Can you find the cavity plugs? I just spent 5 minutes on Mouser without any luck...
Most of the the work that I have done has been will GM's E38 ecm. Below are the two connectors for the E38. They don't seem to list a cavity plug at all. I have completely stripped a few factory GM harnesses any I've never seen a cavity plug in a factory setup either. There is a build in seal in the connector that seals around the wire when you insert it. The wire openings in this seal are very small. You could just cut up some scrap 20/22 gauge wire and insert it in the unused spots.
http://www.molex.com/molex/products/...P_HOUSINGS.xml
http://www.molex.com/molex/products/...xml#partdetail
Jason Mitchell
1971 Camaro 416 LT1 Project
