Old 08-19-2013, 09:12 PM
Schwartz Perf Schwartz Perf is offline
Supporting Vendor
Glad you minitubbed it
SchwartzPerformance
SchwartzPerformance.com
GMachineChassis.com
LSxEngines.com
Facebook | Instagram | YouTube
Old 09-01-2013, 07:36 AM
renegade6 renegade6 is offline
Default Biscayne (Impala) B Pillar and quarter panel repair
Finally got to the part that I was dreading. The B pillar had been hit at some point and whomever the piece of humanity who painted it before fixed everything with a gallon of bondo. The B pillar was a bit intimidating because, the replacement part came with the entire inner window structure and it isn't an exact match for a Biscayne.
After looking at it for a bit, we decided to go ahead and cut out the damaged portion and graft the new piece on the old one. I'm very happy with the quality of the replacement B pillar however, I can't say the same for the quarter panel patch.
The quarter panel patch is a POS. If anyone has to do one for an early Impala, Biscayne, etc., I would recommend going with an entire quarter (believe these are stamped better) and cut out the portions you need. The quarter came out OK, had to add in a piece of metal and some welding rod to fix the door gap and that is still a work in progress. I have a high spot on the back of the patch and a few low spots but, nothing that can't be fixed.
BTW, I'm getting very comfortable with stitch welding and plug welding
63 Biscayne
Schwartz Performance Chassis
Build thread: https://lateral-g.net/forums/showthread.php4?t=37302
Old 09-15-2013, 05:37 PM
Default Floors
Well, I've made some progress with the floor with a lot of help. A bit of a learning curve with doing bead rolling and oil canning but, nothing that we won't figure out. So far, the floor boards are done with the first part of the transmission tunnel. Not a lot of sexy stuff here so far...I figure I'm about six months or so away from that.
63 Biscayne
Old 09-22-2013, 04:03 PM
Default Mock-up Engine
I didn't get much accomplished this weekend. I've been out of commission for a few days after having my wisdom teeth removed...Finally. If I can give some advice to the younger viewers. Do it now and do wait until you're in your 40s.
I've been looking around for a mock-up block so that I can have better measurements when I build my firewall and new inner fenders. A new plastic mock-up engine is about $300 so, I figured I would check out the local junk yard to see if they had anything scrap that I could get.
Well, $200 later I have an 5.3 LM7 out of a 2002ish Avalanche and from what I can tell, the only thing wrong with it is the intake and oil pan are cracked from having a tree fall in it. As you can see, the cross hatching is still there on the cylinders and when I pulled the valve covers off, there was zero sludge inside.
I may go ahead and use this at least to get me going and save up for some more for what I want or, mod the hell out of this.
63 Biscayne
Old 10-15-2013, 04:44 PM
Default Floor, firewall and trunk finished (Impala, Biscayne)
Been kind of slow on the updates. The reason is that I've been busy with a lot of help.
As a result, the floors, trunk and firewall are all finished. Now on to the hard stuff...Fixing dents, finishing the rust repair, sanding, sanding and more sanding. I am extremely pleased with how everything came out and without some help, I'm afraid of what it would have looked like.
On to the pictures.
63 Biscayne
And I forgot. A little more welding and a crap load of grinding.
63 Biscayne
Old 11-10-2013, 04:14 PM
Default Windshield wiper motor, etc.
Nothing too exciting to update on.
-took the car off the frame and on the rotisserie. To help hold it up, decided I needed to make some cribbing blocks
-managed to fit the late model GM windshield wiper motor
-finished removing all of the rest of the rust and undercoating under the rear half
-re-fitted the center body to frame supports
-capped off all of the floor supports
-made a driver's side rocker patch and welded it in
-welded and capped off the rear trunk supports
-welded in the trunk firewall
-fit and started welding the driver's side quarter patch...Would have finished if I did run out of gas and wire.
As you can see from my list that I conveniently wrote on the side of the car, I have a crapload more to do...Before I have to come up with the next list.
63 Biscayne
