Old 08-29-2013, 07:09 PM
SWAPMEETCRAZY's Avatar
SWAPMEETCRAZY SWAPMEETCRAZY is offline
Default Ring Brothers New C10 Handle....well Sort Of!
Was a real pain but in the end I like it.....As u can see these are RB"S 1st gen Camaro handles ......had to cut up 2 new 69 panels to get the geometry right....and do to the extreme angles from buttons to bear claw release i chose to use handles to electrically open door....started with early 70's repop alarm sws which are identical on outside to the stock lock cylinders...batt to them then to h.d. limit sw...push button..batt to h.d. door popper....pulls bear claw
Turn key sw 90*...no batt...effectively locked from outside...inside car..will have a mechanical door handle to release...and a cutoff sw for outside battery mounted in console....Sounds technical...but really simple and effective......jim
Old 08-29-2013, 07:11 PM
more.......
Old 08-29-2013, 07:13 PM
And yes handle was moved 1 1/4" down....also totally clears one-piece windows.....jim
Old 08-29-2013, 07:25 PM
ccracin's Avatar
ccracin ccracin is offline
Awesome Jim! Glad to have you back! Lol
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 08-29-2013, 07:33 PM
Workin on hangin the accuair this weekend....see Mr Porters' belly mounts on the floor.....they are simple and sweet...holds air tank,compressor...one on each side behind cab..........more later...........jim
Old 08-29-2013, 08:52 PM
tazzz2_ca's Avatar
tazzz2_ca tazzz2_ca is offline
Not sure what year specific C-10 you're building, but I just finished the molds for 67-68 Carbon hoods if they are of any interest to you....
-73TA WarPath (Summer 2016)
-72RS Il Vagabondo
-70 Blue Formula "Project Cochise"
-70 Z shell
-70 Formula shell
-70 Formula roller
-68 Eldorado
-67 Coupe De Ville convertible
Old 08-29-2013, 09:00 PM
68 and yes i am!! Sure Chad is too!! Wondering if it would work with Mr Porter's hinge setup I am running??
Old 08-30-2013, 05:09 AM
ccracin's Avatar
I would love a Carbon hood, but can't go that route on this project. First and foremost i would get fired if I even suggested it. My Dad would flip after he has already bought 2 steel hoods and we have cut one completely apart to make it fit. Second, he wants a cowl induction hood which Albert not making at this point. The second point is what makes it ok. Can't have what doesn't exist! But Jim on the other hand, you really should have one!
Chad
Instagram - @cctek
Old 08-30-2013, 06:31 AM
tazzz2_ca's Avatar
As long as you provided the fasteners you plan to use,, and a measurement for where they need to be placed on the hood it shouldn't be a problem at all... Think of these hoods like steel for the most part with the exception of mounting surfaces.... We have to place a steel plate within the hood to receive the the bolts as you can't thread to composites alone...
With the custom mod's you're making, a nice flat finished Carbon Ram Air Hood would look sinister and very cool on the build I'd think.....
-72RS Il Vagabondo
-70 Z shell
-70 Formula shell
-70 Formula roller
-68 Eldorado
Old 08-30-2013, 07:03 AM
V8TV's Avatar
V8TV V8TV is offline
Albert, do you have the website up or a catalog of all your parts somewhere?
Kevin Oeste
V8 Speed and Resto Shop
V8TV
Muscle Car Of The Week
V8 Radio Podcast
All about us:
https://www.v8speedshop.com
