Old 09-07-2013, 05:45 PM
RBuhr69's Avatar
RBuhr69 RBuhr69 is offline
Default Ridetch 4 link
Please understand no complain for Ridetech product and yes it is Saturday so tech support is closed..
Ok, I got all the rear end suspension parts bolted up, got the 4 link bar installed, trailing arms bolted in under car, spring purch bracket for trailing arm bolted up on the leaf spring purch with u-bolts, shocks are bolted up...BUT, the rear and is not centered in the car..Axle tube brackets are equal on the tubes....
How in the world do you center the rear end under the car to make clearance for your tires? Rear end is pushed too far to the left now 3/4 off...
How can I adjust/compensate for this, Got me puzzled.....
