Old 09-07-2013, 10:33 PM
Sieg's Avatar
Sieg Sieg is offline
I've seen better
I've seen better as well
Old 09-08-2013, 07:57 AM
I've seen better
Now that's a Ford I would allow in my garage.
But of course this one trumps that.
Old 09-08-2013, 08:05 AM
When Brett and I stopped by to grab my engine on Friday, Mike @ Watson Racing just happened to be dynoing a 650 cubic inch Pro Stock motor.
The sound made the hairs stand up all over my body. The hairs did stand up when my motor was on the dyno, but that was for different reasons.
1400+ hp
1000+ ft lbs
Enjoy.
Old 09-08-2013, 10:38 AM
FETorino's Avatar
FETorino FETorino is offline
The Digital 6 (6520) does have the start retard built in. The programmable 6AL-2 (6530) does not. You program it exactly how you want it. I have the 6AL-2 and I think you do too?
http://www.msdignition.com/forum/showthread.php?t=14791
Ok I have been playing with my new MSD 6AL-2 programmable box and trying to set up a fuel curve here. First time doing this and wondering what you guys think.
Yep you're right , got me there, there isn't a switched start retard like on the 6520. You can just take 30 deg out below 400 that will make starting easy. Fix that on your timing map will you.
Now explain to me where in the instructions the MSD controls adjusts the carb jetting to control the fuel curve?
Rob in SoCal
Old 09-08-2013, 10:52 AM
Egg Sack Lee
I too, noticed the "fuel curve" and just left it alone.... but I had started loading the ammo....
Old 09-08-2013, 10:56 AM
You guys knew what I meant...
Old 09-08-2013, 11:13 AM
fleet's Avatar
fleet fleet is offline
Old 09-09-2013, 04:47 PM
tones2SS's Avatar
tones2SS tones2SS is offline
When Brett and I stopped by to grab my engine on Friday, Mike @ Watson Racing just happened to be dynoing a 650 cubic inch Pro Stock motor. The sound made the hairs stand up all over my body. The hairs did stand up when my motor was on the dyno, but that was for different reasons.
HA HA!! Nice one Dave.
Old 09-10-2013, 09:04 PM
Ok so I was guided to make one more change for the initial map and to add some timing at idle speed. Here is where I am at now. Will be fun to play with it on start up and see how it reacts to some small changes, if anything.
Old 09-10-2013, 10:13 PM
Sieg's Avatar
I hope your start up goes much better than mine!
Congrats on 3000 post too.
