Old 06-24-2006, 07:46 PM
Matt@Lateral Dynamics Matt@Lateral Dynamics is offline
20's on a B body Mopar.
Old 06-24-2006, 08:19 PM
murtah's Avatar
murtah murtah is offline
The "new" part for DSE's Quadra link is a reiforcement for the Pan hard bar bracket on the pass side frame rail. The attached letter states that if you use your car on the track, the reinforcement is recommended. They discovered this recently when they were testing the rear on a track.
You can still use your stock rear seat but you need to trim some of the springs on the bottom as well as the upper sides for the mini tubs.
Old 06-24-2006, 08:54 PM
Dodgenut64 Dodgenut64 is offline
wow nice B body, got anymore pics?
Old 06-24-2006, 09:08 PM
4mm 4mm is offline
Mark, is that the Mopar you told me about that was built in SA?
Old 06-24-2006, 09:22 PM
http://www.lateral-dynamics.com/gallery/plum_floored/
Old 06-25-2006, 02:45 AM
Mean 69 Mean 69 is offline
Yep, that's her. Pretty cool car, some really nice body mods, it's mean looking for sure. Really neat FI unit for the 6.1 HEMI engine too.
Mazspeed, take a look at our site for more info on the setup, if you haven't already (which it appears that you have), we tried to include a good amount of content to help explain our design approach. You already nailed it, this isn't a bolt in affair, in our educated and professional opinion, it's not a viable possibility due to the packaging constraints these cars have. We could have made a bolt in deal, but the performance compromises associated with that option are not ones that are not acceptable to us.
One clear point that sets our setup apart from every other unit out is the length of the control arms, as you noted. This was done with our eyes wide open, based upon the results of countless mathematical results, testing with our own car, and exhaustive research with folks that have been there, and done that (with a big emphasis on amateur and professional road race teams/engineers). At some point, you reach a point of diminishing returns, but longer is better, the physics say so. Stick axles need to be able to move up and down quite a bit to provide the most grip under a variety of circumstances, and as they move, the critical suspension geometry parameters change. The rate at which they change is directly proportional to the length of the links.
I have not personally installed the DSE system, but as you can imagine, I have seen several pictures of it. In relative terms, there might be a bit more work to install our setup, but it's not significant, it's actually a LOT easier if you construct your own rear housing, our setup comes with a completed fully welded housing. The main difference is that we insist loads be reacted through a rigid crossmember, our forward crossmember is probably the most tedious part to install, not hard, just tedious. If you have the ability to install a set of through floor subframe connectors, or if you are going to take on a mini-tub job, you can handle the installation of this kit.
Whatever you decide, have a great time with your car and enjoy the journey!
Best of luck,
Mark
Old 06-25-2006, 05:38 AM
68protouring454's Avatar
Default maz
here is a shot of how low the lca brackets are, which really are not that low, my car will be one of the lower cars with the 3 link in it and there is plenty of room, this kit can be installed in the same amount of time or less then a set of mini tubs with closeouts,
think about it, when one side of an axle goes into bump, it wants to go up and in towards the center of the car, so imagine the axle trying to do this with a 4 link whether it has swivels or not, it will bind, the swivels help it but the uper link just will not let the axle move smoothly, now think about it with a 3 link, it as good as it gets with a stick axle,
this is a shot of clearance, althought he car looks high the roof is 49 inches off the ground, and theres 6 inches to 5 inches the bottom of the rear end.
Old 06-26-2006, 06:06 PM
mazspeed's Avatar
mazspeed mazspeed is offline
Wow guys, thank again for all the answers on this. I'm going to seriously consider the 3 link highly when it's time to tear it back down again.
