Old 10-24-2013, 11:50 AM
Proforged Proforged is offline
Originally Posted by David Pozzi View Post
Moog used to make an optional HD idler, I had one on my Camaro.
David - do you have a part # on this?
Zack Kanter
President
Proforged Chassis Parts
www.proforged.com
Tall Ball Joints, Tall Tie Rods, Billet Adjusting Sleeves, and Steering Linkage Kits for Musclecars
Old 10-24-2013, 10:56 PM
David Pozzi's Avatar
No, I have an old Moog catalog, but it starts at 1971. I do still have the idler arm. I think it had a nut on the bottom, & bolted to an L bracket off the frame rail.
http://www.PozziRacing.com
Old 10-25-2013, 12:31 PM
CarlC CarlC is offline
The replacement pitman arms have similar plastic inserts. They wear very quickly when used in high-load situations.
Here's a bronze replacement for the plastic insert. So far it has four years of serious abuse and shows zero signs of wear. When the time comes for the idler arm I'll go either the Proforged route or make something similar.
Uploaded with ImageShack.com
http:www.vaporworx.com
Old 10-25-2013, 01:54 PM
Regal454 Regal454 is offline
Originally Posted by 68LS1 View Post
At least 3/4".
Attachment 42703
cheers
Who makes the bronze replacement bushing? Are the Proforged idler arms currently made with the bronze bushing?
Old 10-25-2013, 03:51 PM
Our arms are not currently made with a bronze bushing. We are very interested in this, too - Carl...who makes that?
Zack Kanter
President
www.proforged.com
Old 10-25-2013, 08:41 PM
Rod P's Avatar
Rod P Rod P is offline
me too!! my car gets driven very hard!! I would interested in a HD version of what I have or a rebuildable design
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 10-25-2013, 08:44 PM
Sieg's Avatar
Sieg Sieg is offline
I was thinking Delrin but looked up the thermal properties and they appear to be on the low side for tight exhaust clearance with high loads: http://www.sdplastics.com/delrin/delrin[1].pdf
Old 10-28-2013, 06:53 PM
Sieg's Avatar
I removed the GM Pitman arm and installed the Moog K6099 replacement Pitman arm on the car today and the Moog arm compressed against the header as it was tightened to the frame. The OEM arm had just over .25" clearance.
A bronze replacement bushing for rebuilding the OEM arm would be real nice in my situation.
Doug's D368 headers, GM OEM motor mount perches, Moroso 62150 solid mounts.
