Closed Thread
Old 10-26-2013, 11:30 PM
FETorino's Avatar
FETorino FETorino is offline
Go 450-475 dressed? Not bad....
Yep.
The stand the motor is on is probably 15 so subtract that to get 360lbs starting weight.
The Findanza flywheel is 14lbs
My CVR waterpump is 5.8 lbs and the adapters are another 3.
My 3G alt is 15.4 lbs
RST clutch and pressure plate are 22.5lbs.
PS pump I'm not sure but maybe 15lbs.
Holley carb 13 lbs
Most the oil is back in the tank.
That's 82 lbs + maybe another 5 to 7 for the AL brackets.
So it should be right about 450 or a little less.
Need to add headers though they might as well count as part of the motor.
Rob in SoCal
Old 10-27-2013, 06:16 AM
DOOM's Avatar
DOOM DOOM is offline
BB's forever Rob! They have no idea!
Mario
USCOLLISION
Old 10-27-2013, 08:52 PM
TAC TAC is offline
Rob, that's impressive. I never would have thought the engine would be that low weight, even with all the alum..
I have a few small parts for the dash if you need something. I won't be using on my car. Let me know what you may need, free to good home.
I also have a few exterior parts.
71 bronco...fully custom built...daily driver
69 Torino...to be built
gary
Old 10-27-2013, 09:22 PM
what did that bellhousing weigh? not too shabby. Tell Brett he should put you on payroll.
Old 10-27-2013, 09:44 PM
Yep.
Holley carb 13 lbs
The entire LOTUS weighs 1450….
Think about that. What's that -- your motor and trans and 4 wheels???
HAHAHAHAHAHAHAHAHA
I was amazed at your weight of the motor though I have to say!
Old 10-27-2013, 10:14 PM
FETorino's Avatar
I think I have all the dash parts I need but you never know.
The bell weighs 24lbs.
HAHAHAHAHAHAHAHAHA
When I bought the block it shipped regular UPS since it was less than 115lbs.
BTW GW all 4 wheels are less than 100lbs.
Tires are 136lbs
Trans is another 135lbs
So we'll need a few more parts to hit your 1450 #.
One day when I'm done with this car I'm putting together a backup track car. a Factory Five 818R. Sure it's heavy but it will have 225 hp.
Rob in SoCal
Old 10-27-2013, 11:33 PM
Sieg's Avatar
Sieg Sieg is offline
Rob - I guessing you've weighed the brakes?
Did you get a rolling chassis weight?
Old 10-27-2013, 11:36 PM
67zo6Camaro's Avatar
67zo6Camaro 67zo6Camaro is offline
Yep it's _____. Well I better let him tell you. lol. but all I can say is it's not bad. Final weight could see the 3200lb mark.
Old 10-27-2013, 11:48 PM
Sieg's Avatar
Very respectable
My car is 3360 with 10 gal of fuel in it.
Old 10-28-2013, 12:28 AM
FETorino's Avatar
Yep the chassis and body were lbs.
Kinda heavy.
Rob in SoCal
Closed Thread
