Old 10-29-2013, 07:00 AM
AM.MSCL's Avatar
AM.MSCL AM.MSCL is offline
I guess maybe I should mention that the car had been running just fine for 2 years with the exception of issue number 1.
I current have 10 degrees of timing which is the max I could do without introducing lifter clatter at high rpms.
If I remember correctly I had 15 units of vacuum when I tuned it.
Old 10-29-2013, 09:52 AM
Sieg's Avatar
Sieg Sieg is offline
Sounds like the issue started with installation of the pressure gauge.
Did you use teflon tape or some type of thread sealant that could have clogged a passage in the carb?
Has E10 fuel sat in the carb for an extended period?
Could the gauge be restrictive/defective?
Fuel pump possibly giving up? I just had a mechanical pump start to fail in the middle of resolving idle issues.
10*-12* initial timing should be fine and 32*-36* total timing.
The idle transfer slots in the venturi's should be set to expose .020" for a baseline.
Idle mixture screws are usually in the .75 to 1.50 turns out range.
The way it's seeking a high idle then falling off means it "could" be lean. Vacuum leak or idle mixture setting and/or butterfly transfer slot relationship.
Accelerator pump linkage should have a .010"-.015" play also. Too tight and the pump can weep fuel into the idle mixture.
All these settings should get you close......but if a circuit is experiencing blockage or there's a vacuum leak or fuel supply issue you'll have issues.
Old 10-29-2013, 09:40 PM
Call Eric - he's there in Austin.
He's on this forum… and also Carbuff is there as well as Gerno… They can point you how to get hold of Eric.
Go to this thread - find the guys and PM 'em if you don't know them.
https://lateral-g.net/forums/showthread.php4?t=29609
