Closed Thread
Old 10-27-2013, 10:14 PM
FETorino's Avatar
FETorino FETorino is offline
Originally Posted by TAC View Post
Rob, that's impressive. I never would have thought the engine would be that low weight, even with all the alum..
I have a few small parts for the dash if you need something. I won't be using on my car. Let me know what you may need, free to good home.
I also have a few exterior parts.
I think I have all the dash parts I need but you never know.
what did that bellhousing weigh? not too shabby. Tell Brett he should put you on payroll.
The bell weighs 24lbs.
The entire LOTUS weighs 1450….
Think about that. What's that -- your motor and trans and 4 wheels???
HAHAHAHAHAHAHAHAHA
I was amazed at your weight of the motor though I have to say!
When I bought the block it shipped regular UPS since it was less than 115lbs.
BTW GW all 4 wheels are less than 100lbs.
Tires are 136lbs
Trans is another 135lbs
So we'll need a few more parts to hit your 1450 #.
One day when I'm done with this car I'm putting together a backup track car. a Factory Five 818R. Sure it's heavy but it will have 225 hp.
Rob in SoCal
  #1642
Old 10-27-2013, 11:33 PM
Sieg's Avatar
Sieg Sieg is offline
Rob - I guessing you've weighed the brakes?
Did you get a rolling chassis weight?
  #1643
Old 10-27-2013, 11:36 PM
67zo6Camaro's Avatar
67zo6Camaro 67zo6Camaro is offline
Yep it's _____. Well I better let him tell you. lol. but all I can say is it's not bad. Final weight could see the 3200lb mark.
  #1644
Old 10-27-2013, 11:48 PM
Sieg's Avatar
Very respectable
My car is 3360 with 10 gal of fuel in it.
  #1645
Old 10-28-2013, 12:28 AM
FETorino's Avatar
Yep the chassis and body were lbs.
Kinda heavy.
Rob in SoCal
  #1646
Old 10-28-2013, 03:57 AM
jarhead's Avatar
jarhead jarhead is offline
Rob, does the T56 QT bell have to be indexed? Seems like it has a huge hole, unlike the TKO that slips around a collar on the trans/input shaft.
Whatever you do, don't index it, laying on your back, under your "Torin" while it is up on saw horses. It is a pain.
Joe, Lance Corporal in the Jack stand Army
joe
Semper Fi
My 68 Torino
  #1647
Old 11-05-2013, 12:27 PM
jarhead's Avatar
Hmmmmm...
I see someone was thinking ahead and said "Rob may want to run some exhaust pipes through here"
Been studying these pictures, and thinking???
joe
Semper Fi
My 68 Torino
  #1648
Old 11-05-2013, 01:25 PM
Why don't you less time on here and weighing everything and being defensive about Betsy's weight situation and more time making progress?
You got your parts.
You got a shop to work in.
You have tools (Brett's).
And you have Brett when you get in trouble.
So what's your excuse Sally?
Oh, and I'll see ya tmrw...
  #1649
Old 11-06-2013, 05:36 PM
Wissing72's Avatar
Wissing72 Wissing72 is offline
Dig seeing the progress Rob!
Chris
70 Chevelle. Roadster Shop Chassis, The shop llc/ Jon Lind interior LS3/6speed. Thanks to Precision Classics and Collision Eugene, Or. http://precision-classics.com/
Build thread:https://lateral-g.net/forums/showthread.php4?t=39517
  #1650
Old 11-16-2013, 02:34 PM
FETorino's Avatar
Thanks Chris
How about some Parts pictures? are those good?
As I kept trimming the firewall further and further to give myself clearance to set the motor down and back it became apparent that the stock hanging pedals weren't going to cut it.
Here was the first test fit with a minimal cut. In this picture the motor was still .25" off center and you can see I have no clearance between the VC and remaining firewall. You can also see how close the 4 bolts that hold the stock pedal hanger are to the VC. I ended cutting the firewall to the other side of the mounting holes so no more stock pedal hanger.
Earlier in the week Brett had pointed out I had plenty of room for a floor pedal set up. I agreed with him but my concern was the header collectors need to go somewhere and that path would be down near the footwell. But after cutting the firewall to where I wanted it and measuring it was clear I have a lot more flexibility with fitting the floor pedals than a hanging set.
So I went shopping.
Although this is a 600 series Tilton Pedal set up it has the 900 series bracket to run the Series 77 master cylinders. The mounting of these is supposed to eliminate binding in pedal travel and the migrating of the bias due to some of the binding.
Having put the motor in the chassis where I want it to sit it is also clear that a front plate and midplate set up would make sense for mounting the motor.
The front plate will also give me a nice plane to use for the PS pump and alt mounting brackets that don't yet exist. Since I have a Peterson stackable mandrel drive I can use whatever existing PS or Alt brackets I like the look of and tailor the belt alignment via the position of the pulleys on the Peterson Mandrel. Those parts arrived long time ago so here is a reminder what they look like. This is better than digging through the wrecking yard this thread sorta is.
The Midplate will be a custom piece that Brett will fab. The front plate I got from Chris Alston Chassisworks. It has plenty of extra material I will trim off once all the final mounting positions of the motor and accessories are determined. As you can see in the photo my chief parts guy checked it all out and told me it was good to go.
Rob in SoCal
Closed Thread
