Old 11-29-2013, 07:19 PM
INTMD8's Avatar
INTMD8 INTMD8 is offline
Thats a fair price for an LS/T56. They were cheaper and easier to come by a few years ago. Even though the engines themselves are getting older they are in higher demand now.
One thing I'll mention is if you really want to run it flex fuel and you want to use a GM ecm you'll want a newer engine with a 58x reluctor wheel. Then you can use an E38 ecm along with a fuel composition sensor.
Other options are to switch the reluctor wheel and cam gear in the LS1 to run a newer ecm, or use aftermarket engine management with flex fuel capability.
Old 11-29-2013, 07:24 PM
OBeer-WAN-Kenobi's Avatar
Are there any good options for an after-market engine management system that will run flex and will work for forced induction (when I have the money to add it). I've looked before and it seems it's hard to get the best of both worlds. I've been interested lately in the Holley dominator with it's self learning but don't know if it would work for this. I'm willing to learn to tune and even bought a book on tuning the ls series of engines but something that's more plug and play would be great.
Thanks for everyones help so far!
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 11-29-2013, 08:53 PM
INTMD8's Avatar
Big Stuff3 or ProEfi can both do it but my personal preference for something like this is the stock GM controller.
HP tuners has custom speed density operating systems which work excellent for boosted applications.
Old 11-30-2013, 08:12 AM
67Rally's Avatar
67Rally 67Rally is offline
You should be able to pick up a complete LQ4 or LQ9, iron block 6.0l for under $2000, plus a T56 trans for under $2000. Better starting point for building power down the road.
Old 11-30-2013, 08:22 AM
The LQ4 or LQ9; yes. I can get those cheaper than that actually, at least in my neck of the woods. However; it seems to me that by the time I add all the proper accessories, oil pan, intake and misc it becomes more expensive pretty fast. Am I wrong? Is there something I'm missing?
I sure wish the stupid T56's weren't so ridiculously expensive. It's pretty bad when a modern era transmission from a salvage yard is going for more than a date code correct/car matching M22. Does anyone have a source of decent rebuild ones?
'69 RS Camaro
Old 11-30-2013, 08:41 AM
glassman's Avatar
glassman glassman is offline
What i did on the tranny was picked up an LT1 t-56 (i had a sbc at the time) and 2nd gear was bad (typical on these), so when i did my LS swap, i went too Rockland Gear and ordered their kit to convert. I picked up the tranny for 900, the kit was 400 and the rebuild kit was 700 ish if i remember correctly. I paid for labor which was 700 or so and ended up buying two input shafts (one for the LT which i still have brand new and one for the LS)
So, if you can source an LT (800+/-) the kit for 400+/- and the rebuild kit (it turns the tranny into a magnum) for 1200+/-, you have a very stout tranny and waaaay stronger than a stock LS tranny....
Mike
Old 11-30-2013, 04:15 PM
Instead of doing that, if I wanted magnum strength, couldn't I just snag one out of a 2010 + Camaro to get a stronger transmission? Isn't the TR-6060 basically a T-56 magnum? I think I can get one of those with pretty low mileage for a little over 2K. Maybe there are some other problems associated with that swap that I'm unaware of?
'69 RS Camaro
Old 12-01-2013, 10:29 AM
67Rally's Avatar
I picked up an LQ9, complete with all accessories, harness, pedal, ecu, tac module, etc. for $2k. The LQ4's were running a couple hundred less at the time. A long block would be a lot less, just depends whether you will re-use the accessories. In the end, I sold everything off the LQ9 and bought all new shiny stuff amyways.
I just think the 6.0 is a better starting point, but you have to figure out you end goal, do your research and plan accordingly.
With an LS1, you won't be able to re-use the oil pan unless you modify it anyways. And if I recall, you'll probably have to relocate the alternator or modify the cross member as well.
LS1 is probably easier, but you're a little more limited. Smaller cubes, the heads don't flow as well (both engines respond well to a set of 243's), and the intake is good, but you'll probably want to swap in an LS6 intake once you start doing upgrades anyways.
Just random food for thought.
