Old 12-01-2013, 11:18 AM
Ron Sutton's Avatar
Hi Brian,
What your describing will be more a function of spring rate, sway bar rate & shock valving, so make those your priority.
Most of the rear suspension designs available ... 3-link, 4-link, triangulated 4-bar, torque arm, leaf spring, etc ... can achieve this ... with the correct spring rate, sway bar rate & shock valving.
I suggest going with the largest oem shape 1-piece sway bars available for your application (front & rear) combined with moderate spring rates and high quality adjustable shocks. this will produce a responsive handling car without riding like a 1-ton truck.
Someone with more street ride quality experience than me should suggest rates, but I'm thinking in the 500-550# range in the front and the rear rate ... 175-225# will depend a lot on where the springs end up mounted from the car's centerline (motion ratio).
I would suggest you go away from the leaf spring set-up if you can afford to. If you're not competing with it, you probably don't need it to be adjustable, so a torque arm or triangulated 4-bar set-up may fit your needs and keep the suspension simple.
Best wishes !
Ron Sutton Race Technology
Old 12-01-2013, 03:33 PM
Rod P's Avatar
Rod P Rod P is offline
yep you have it Ron, great for street with big ole-sway bar up front, and the best single adjust shock you can afford, don't cheap out on the shocks, I have seen a lot of good setups JACKED UP with bad shocks and tires
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 12-01-2013, 07:16 PM
conester2013 conester2013 is offline
Ok Ron/Rod, I was looking at the set up below…does this look like it would be a good setup for me given my goals for my cars handling?
http://www.ridetech.com/store/1967-1...m-level-2.html
If I didn't do that, to save some money, maybe I could go with the chicane system here:
http://www.speedtechperformance.com/...prod/prd12.htm
Some QA1 upper and lower arms:http://www.qa1.net/qa1_motorsports/d...trol-arms.html
Some single adjustable ride tech coil overs on the front and back and the 4 link from ride tech in the back: http://www.ridetech.com/store/1967-1...rd-airbar.html
Oh yeah….and of course a giant sway bar up front/back.
How does that sound?
Thanks again for the help!!
Brian
Old 12-01-2013, 08:55 PM
chichirone's Avatar
chichirone chichirone is offline
Brian, you will be very happy with the Ridetech setup. Add the Musclebar if budget allows. Its a nice piece and was a major improvement to the way my car drives. It will give you the street handling and ride you are looking for and plenty of adjustability with the SA's. Plus, you leave yourself options for future upgrades or changes if you want to make the suspension more aggressive. I've been very pleased with the Level 2 setup on my car, plus Musclebar and TruTurn. I've played with camber and toe adjustments. The shock settings for track and street. Different spring rates which Kyle from Ridetech has been a huge help. I haven't played with the triple adjustables yet on our 73 TA but get a notepad out when you start adjusting the shocks and document how the car feels after you make changes until you find your preference for street and spirited driving or even a track day/autocross setting if you get into that. Best of luck with your suspension project.
Jay
1973 Trans Am "KLRBRD"
1969 Camaro SOLD
2014 Stingray Z51 SOLD
Old 12-01-2013, 09:41 PM
Rod P's Avatar
don't want to sound like a sales man for ridetech, but I agree with the previous poster, I switched my car from a leafspring setup, to a complete ridetech set up and it runs among the top elite at every event and I haven't even fully tuned the car yet, that setup with fat tires in all four corners is awesome
Rod Prouty
Bangshift Stories
Old 12-02-2013, 08:54 AM
Ron Sutton's Avatar
It's not my place to recommend brands, but all of the ones you're looking at are quality pieces from quality companies. You'll need to decide what you want & who you favor working with. Calling them& seeing how they interact with their customers may go a long way in your decision.
I get a kick out when you guys call these huge sway bars, because we're realistically talking in the 400-500# range and I'm used to running 1500#+ on road course stuff. So to me a 1-1/4 to 1-3/8" front bar, along with the correct rear bar makes for a nice responsive, moderate roll angle street package.
Rod, what do you think he needs as far as spring rate?
Old 12-02-2013, 11:38 AM
Well I pulled the trigger guys!!! All the good things said here about Ridetech and the fact that I saw Matt's Classic Bowties was having a cyber Monday and forum sale so I jumped on that! I bought the Level 2 Ridetech coil over suspension system with the front muscle bar!! Talking with Kim at MCB, based on my engine and how low I wanted it to sit, she said I'd be looking at 550# springs.
I'm pumped!!! Funny how it works…initially I was going to go with the QA1's and keep leaf springs in the back, and now I am getting rid of the leafs and upgrading the coil overs and putting them in all four corners!!
Thanks again for all your help guys!! It's all your fault that I went with this system!!!
Brian
