Old 12-05-2013, 09:02 PM
coolwelder62's Avatar
SC, The car is coming along great.Your part's are all cut and waiting to be welded.
Old 12-05-2013, 09:05 PM
Ron in SoCal's Avatar
^ Big Mock...4k posts
Ron in SoCal
69 Camaro in progress
Old 12-06-2013, 05:40 AM
renegade6 renegade6 is offline
How are you heating your garage to paint?
63 Biscayne
Schwartz Performance Chassis
Build thread: https://lateral-g.net/forums/showthread.php4?t=37302
Old 12-06-2013, 07:04 AM
Sonar Chief's Avatar
Thumbs up
Thanks Scott .... I'm excited to see it!!!!! Question .... does it matter who I get the solid body bushings from? Just wanted to make sure before I ordered.
I have a little torpedo propane heater from HD ... when it gets below 30 (it's -4 degrees now!!) it's not going to heat the garage or the car enough to paint. That is why I sprayed when it was 50 and it was easier to heat things up to 70 degrees.
I can't wait for the cold front to get the heck outa here so I can get back in the garage .... supposed to be 10 degrees today!!!
Old 12-07-2013, 03:41 AM
makoshark makoshark is offline
Did you order a Scott Mock subframe!?
Old 12-07-2013, 07:26 AM
Cool How'd u know?
I did should be here for Xmas
Old 12-07-2013, 07:43 AM
Awesome! Can't wait to see the pixes of it. What else have you bought that you're holding out on us about?
Old 12-07-2013, 08:00 AM
No, as long they will fit an 1.5 hole in the frame.
