Old 12-06-2013, 05:40 AM
renegade6 renegade6 is offline
How are you heating your garage to paint?
63 Biscayne
Schwartz Performance Chassis
Build thread: https://lateral-g.net/forums/showthread.php4?t=37302
Old 12-06-2013, 07:04 AM
Sonar Chief's Avatar
Thumbs up
Originally Posted by coolwelder62 View Post
SC, The car is coming along great.Your part's are all cut and waiting to be welded.
Thanks Scott .... I'm excited to see it!!!!! Question .... does it matter who I get the solid body bushings from? Just wanted to make sure before I ordered.
I have a little torpedo propane heater from HD ... when it gets below 30 (it's -4 degrees now!!) it's not going to heat the garage or the car enough to paint. That is why I sprayed when it was 50 and it was easier to heat things up to 70 degrees.
I can't wait for the cold front to get the heck outa here so I can get back in the garage .... supposed to be 10 degrees today!!!
Old 12-07-2013, 03:41 AM
makoshark makoshark is offline
Did you order a Scott Mock subframe!?
Old 12-07-2013, 07:26 AM
Cool How'd u know?
I did should be here for Xmas
Old 12-07-2013, 07:43 AM
Awesome! Can't wait to see the pixes of it. What else have you bought that you're holding out on us about?
Old 12-07-2013, 08:01 AM
Cool
Holding out? Naw that's it ... just bought the bare frame and I will add the C6 stuff, sway bar and rack when funds come in. I needed a subframe to attach the front end sheet metal to ... so it was an easy choice really!!!!
Gonna run 315's on all for corners
Old 12-07-2013, 08:16 AM
The car should be awesome on Scotts frame.
Old 12-08-2013, 04:54 PM
coolwelder62's Avatar
The bare frame comes with a splined sway bar and hardware kit.I like the DSE body bushing kit.
Old 12-10-2013, 05:58 AM
315's all the way around...nice!
What are you going to use for a front wheel well? Modify the stock ones or aftermarket? The stock ones really don't even accommodate 275's
Old 12-07-2013, 08:00 AM
No, as long they will fit an 1.5 hole in the frame.
