Closed Thread
Old 12-11-2013, 12:51 AM
fleet's Avatar
fleet fleet is offline
Or he could have just bought my Lotus 2 Eleven.
Hey Greg,
Wad's new with you?
Oops, wrong
Old 12-11-2013, 04:17 AM
Rick D's Avatar
Rick D Rick D is offline
Originally Posted by compos mentis View Post
Hey Greg,
Wad's new with you?
Oops, wrong
Rick
Old 12-11-2013, 05:04 AM
fleet's Avatar
Maybe I'll check the 'Body wadded up' forum for progress reports on Greg's lil Loti..
Ok...back to Rob's '8 barrels blazin' build.
Old 12-11-2013, 03:37 PM
intocarss's Avatar
Old 12-11-2013, 10:25 PM
TAC TAC is offline
Hey Rob, good to see some progress pics. I pushed my motor back through the firewall also, but just 5 inches. I am still able to use the stock cowl panel but the firewall will be under the cowl panel a little ways. I did 67 nova with a big block pushed back a few inches and made the cowl a removable piece to access the dist.. Is that kinda what your planning or is the cowl going to become the rear of the hood?
71 bronco...fully custom built...daily driver
69 Torino...to be built
gary
Old 12-12-2013, 09:27 AM
Panteracer's Avatar
Default 1969 Torino
Except the dizzy is in the front on a Ford
so that access is good unless you have a
Pantera and the damn thing is on the wrong end
But a Chebby motor is just not right in a Ford
but my buddy has a Cleveland in his Camero
dry lakes car doing 187 plus. now that is ok
Panteracer Norcal Bob
Old 12-12-2013, 09:32 AM
Sieg's Avatar
Sieg Sieg is offline
Good chassis, good engine.......put the shell of your choice over it and drive it!
Old 12-12-2013, 04:13 PM
intocarss's Avatar
SO when is the 5.4L DOHC MOD MOTOR going in your wreck
Old 12-12-2013, 10:17 PM
TAC TAC is offline
I'm a firm believer in ford car ford engine...Gm car Gm engine and Chrysler car Chrysler engine.....Every other car....Who cares.....
gary
Old 12-12-2013, 10:58 PM
FETorino's Avatar
FETorino FETorino is offline
I'm 7.5" back from where the motor was but that actually puts the back of the motor about 4-5" behind the old firewall so probably the same as where yours sits.
We will rebuild the bottom of the cowl panel to allow for clearance of the valve covers but no need for access through the cowl panel.
The firewall itself will have an access panel to get to the bellhousing bolts so I can get the out without removing the engine.
Bingo on two points Bob.
Yea Sieg when are you making the move?
That's the way I feel, but to each their own.
Everybody has the right to their project up however they want as long as it makes them happy.
Rob in SoCal
Closed Thread
