Closed Thread
Old 12-11-2013, 05:17 AM
Rick D's Avatar
Rick D Rick D is offline
Originally Posted by compos mentis View Post
Hey Greg,
Wad's new with you?
Oops, wrong
Rick
  #1792
Old 12-11-2013, 06:04 AM
fleetus macmullitz's Avatar
Maybe I'll check the 'Body wadded up' forum for progress reports on Greg's lil Loti..
Ok...back to Rob's '8 barrels blazin' build.
Old 12-11-2013, 04:37 PM
intocarss's Avatar
  #1794
Old 12-11-2013, 11:25 PM
TAC TAC is offline
Hey Rob, good to see some progress pics. I pushed my motor back through the firewall also, but just 5 inches. I am still able to use the stock cowl panel but the firewall will be under the cowl panel a little ways. I did 67 nova with a big block pushed back a few inches and made the cowl a removable piece to access the dist.. Is that kinda what your planning or is the cowl going to become the rear of the hood?
71 bronco...fully custom built...daily driver
69 Torino...to be built
gary
  #1795
Old 12-12-2013, 10:27 AM
Panteracer's Avatar
Panteracer Panteracer is online now
Default 1969 Torino
Except the dizzy is in the front on a Ford
so that access is good unless you have a
Pantera and the damn thing is on the wrong end
But a Chebby motor is just not right in a Ford
but my buddy has a Cleveland in his Camero
dry lakes car doing 187 plus. now that is ok
Panteracer Norcal Bob
  #1796
Old 12-12-2013, 10:32 AM
Sieg's Avatar
Sieg Sieg is offline
Good chassis, good engine.......put the shell of your choice over it and drive it!
  #1797
Old 12-12-2013, 05:13 PM
intocarss's Avatar
SO when is the 5.4L DOHC MOD MOTOR going in your wreck
  #1798
Old 12-12-2013, 11:17 PM
TAC TAC is offline
I'm a firm believer in ford car ford engine...Gm car Gm engine and Chrysler car Chrysler engine.....Every other car....Who cares.....
gary
  #1799
Old 12-12-2013, 11:58 PM
FETorino's Avatar
FETorino FETorino is offline
I'm 7.5" back from where the motor was but that actually puts the back of the motor about 4-5" behind the old firewall so probably the same as where yours sits.
We will rebuild the bottom of the cowl panel to allow for clearance of the valve covers but no need for access through the cowl panel.
The firewall itself will have an access panel to get to the bellhousing bolts so I can get the out without removing the engine.
Bingo on two points Bob.
Yea Sieg when are you making the move?
That's the way I feel, but to each their own.
Everybody has the right to their project up however they want as long as it makes them happy.
Rob in SoCal
  #1800
Old 12-13-2013, 06:43 AM
Hot Rodding has ALWAYS BEEN about putting different stuff - from other cars - including other manufacturers on your car. Back in the day - a Cadillac engine was the hot ticket - then it was the Lincoln - then the Olds…
Closed Thread
