Old 12-13-2013, 06:37 AM
aggie91's Avatar
aggie91 aggie91 is offline
for the engine harness I say do it yourself. There are tons of info on the web on how to do it.
I did the one in my son's truck. I used the info on lt1swap.com. I had Zippy Performance in Las Vagas do the computer tune and delete the VATS and make a few other changes as recommended on lt1swap.com. I was not really hard, just very time consuming. I think all told I have about 12 hours in the finished harness. I could easily do one now in a lot less time. I printed out all the info that pertained to my harness and marked off the items as I went.
I have heard good things about the dirty dingo mounts. I built custom mounts for our swap as we set the motor back as far as we could and built a new firewall.
Good luck! The car looks like a nice place to start.
Karl
1965 Chevrolet C10
1982 Chevrolet C10 - My son's Truck - Sunburn
Old 12-13-2013, 09:49 AM
OBeer-WAN-Kenobi's Avatar
Thanks aggie,
I discovered lt1swap.com a few days ago and grabbed the pinout from this link:
http://www.lt1swap.com/2004gto_pcm_pinouts.htm
It doesn't really go through what to keep, and what to get rid of though it does tell you what you CAN get rid of. I've been looking for a step by step somewhere but everyone who posts info on it or makes a video seems to shortcut past all the stuff I'm curious about. I know how to do one BASICALLY but I need specifics. What if I want to keep the stuff that tells me what gear the transmission is in or what if I want to rig in a clutch sensor so I can safely add remote start later? What about A/C and fans? How do I include a relay/fuse box? Stuff like that.
I found a local guy to remove VATS for me just like you did but haven't found anyone to help me out with the harness. I might try posting in the Midwest section at LS1Tech and asking for a "mentor" to do my first one. Haha.
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 12-13-2013, 02:42 PM
aggie91's Avatar
Most of that is on that site. You might have to dig thru the other areas, such as the truck harness step by step he did on the site: This link is updated more recently then when I did mine, now it is on facebook...:
https://www.facebook.com/media/set/?...5211824&type=3
Here is the fuse block and OBDII port for the truck harness:
http://lt1swap.com/fuseblock_obd2port.html
Look at this page:
http://lt1swap.com/2000harness.htm
Karl
1965 Chevrolet C10
Old 12-16-2013, 11:57 AM
Look at this page:
Thanks again aggie,
I found a guy to work with that really seems to know his stuff on reprogramming my ECM to work with Fans and A/C along with some other "enhancements" He's actually sending me the schematics for how I will need to wire the harness to match his calibration. So, HOPEFULLY, I'm no longer in ECM/harness limbo-hell.
I'm going to start another thread for this but does anyone have suggestions on what clutch setup to use for now? I split the transmission and engine this weekend and although it's not that old (plenty of wear left), it looks like the P/O didn't know how to drive a stick as it's got chatter and hot spots all over it. It seems no one resurfaces pressure plates anymore so I'm going to need to buy new stuff if I want to replace it.
My goals; eventually, are as close to 600 RWHP as I can get, but I won't need that kind of clutch performance for a while so i can go with a more factory option for now. What's reasonably priced and a good value?
'69 RS Camaro
Old 12-17-2013, 04:57 AM
im4u2nvss im4u2nvss is offline
LS7 clutch kit, strong, great value. GM part# 24255748
Old 12-17-2013, 05:06 AM
That part number comes up as an LS6 kit not an LS7?
'69 RS Camaro
Old 12-17-2013, 06:39 AM
Not sure why it shows ls6? But part # was for disc and pressure plate only.
http://www.summitracing.com/parts/na...5748/overview/
Here is the clutch kit with pressure plate, disc and flywheel. Under $500.00.
http://www.tickperformance.com/gm-ls...-applications/
Old 12-20-2013, 05:06 AM
72Z/28's Avatar
72Z/28 72Z/28 is offline
Totally agree with you, just got mine installed last month with Keisler Hydraulic TOB kit
72 Camaro RS:SOLD
68 Camaro:
Old 12-23-2013, 06:20 AM
Thanks guys,
I went with a similar lokar cable in my Willys when I swapped in the 5.7 and it worked well. Is there anything special I need for it to hook up to the ls1 throttle body?
I figured I'd just go with the 6cyl pedal both because it's cheaper and because it looks more plain. I went with stock brake and clutch pedals too. Hopefully it will work OK and I won't have too many problems with it.
Hopefully I'll be able to get the old engine pulled out before the end of the year. I plan on trading it for a 12 bolt rear from someone I know.
'69 RS Camaro
