Old 12-18-2013, 03:06 PM
Originally Posted by BBC71Nova View Post
What tig machine are you guys using? Anybody with a Diversion 180?
I run a Miller Dynasty 200DX
Remember that we're welding fairly thin materials usually -- UNTIL you get cranking on some aluminum - and that's when you need so power… so just something to think about when looking for these type machines.
Old 12-19-2013, 06:56 AM
Sieg's Avatar
Sieg Sieg is offline
Nearing micro........at least with my eyes!
Old 12-19-2013, 08:03 AM
RussMurco's Avatar
RussMurco RussMurco is offline
Amazing precision there!
Remember that we're welding fairly thin materials usually -- UNTIL you get cranking on some aluminum - and that's when you need some power… so just something to think about when looking for these type machines.
I know the monster I have available at work can TIG most anything but for a home shop how much power do you suggest for someone who would eventually need the power to weld aluminum??
Russ "Murco" Murray
http://i1339.photobucket.com/albums/...psc7bc7b5c.jpg
"Liquidating excess cash through the automotive hobby!"
Old 12-19-2013, 08:20 AM
1/4" aluminum takes 200 amps…
Remember too - that what you pay EXTRA for this power - the couple times a home builder may need something thicker (bracket etc) he could sure as hell take it somewhere and have it welded far cheaper.
Just always trying to give guys stuff to ponder before they commit is all. I know everyone has different pocketbooks etc. Or maybe their panel wouldn't take another 30amp 220V circuit or whatever.
I like to buy a bit more than the bottom - because as we all know - it's not just THIS project -- once you have "capability" -- there's other stuff you can do and your friends love to find out you have a 'welder' and so forth.
Old 12-19-2013, 09:17 AM
ironworks's Avatar
But you also gain duty cycle and when say boxing frame rails that is an important consideration.
Old 12-19-2013, 10:05 AM
Ordinarily I would agree - duty cycle is important…. but for a home welder that basically sucks - has to constantly reposition - has to check his work every other nanosecond (think SIEG here)… IDK if that duty cycle would be an issue but glad you mentioned it.
Old 12-19-2013, 10:39 PM
Nice work sieg, make sure you ventilate where you weld. Some of the gasses and fumes that come off those colored and aged metals can hurt you.
Maybe a neutral air system should be next on your project list.
How many hours a day are you welding now?
Old 12-19-2013, 11:15 PM
Sieg's Avatar
Vince,
About an hour of actual weld time max.......preps another story as you well know.
The way my bench is set up the TIG unit sits at the same height as the welding table and the fan exhausts forward right across the work area. There's also a heater at ceiling height 4' away the blows over the top of the space. The garage is 780 s.f. so it takes a while to fume it.
Old 12-19-2013, 11:25 PM
Sieg's Avatar
Progress and completion shots.......it's for my Mother Inlaw who's a country girl thus the horseshoe theme.
Every project I learn a new technique, trick, how to make a mistake, and fix it or pay the price of fabing a replacement piece.
Old 12-20-2013, 07:31 AM
Don't use a fan to ventilate your welding area ---- it blows the shielding gas off the weld. Remember there's not all that much flowing there.
Typical welding "ventilating" is done with "extractors" that are overhead of the weld... so that the gas has shielded the weld puddle and then leaves the area.
WE -- meaning us just doing stuff around home - don't breathe enough bad stuff to be an issue. Having said that - there ARE fumes from stuff we could/do weld that are harmful in very small doses. Stuff such as galvanized material (we don't tend to use this in our projects) - and CHLORINATED anything!
Manganese fumes are very harmful --- it's a known fact that in a study of 20,000 welders - 10% (professional welders) developed PARKINSON'S... and the suspected agent is the Manganese that is found in all steels and steel welding rod (filler) etc.
Now -- this is people welding 8 hours a day - 5 days a week - for 20 years... So WE are not really going to be affected by that... but it's still (fumes of any kind) something we should be considering regardless as far as I'm concerned.
