Old 12-31-2013, 10:02 PM
redefined's Avatar
redefined redefined is offline
Yeah a good tuner friend of mine recommended http://www.nickersonperformance.com/ so I sent them an email. My friend doesn't do carbed motors and that's who he sends everyone to who needs that service. They do tunes and build carbs and make cams as well. So we'll see what he says!
I'd be great to still get some nice power out of this motor, even if I have to change a few parts around!
**Some people are like slinkies, they are not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs**
Old 01-01-2014, 11:37 AM
Sparks67's Avatar
Sparks67 Sparks67 is offline
Almost all engine builders don't reply to emails, so it is best to contact them by phone or do a shop visit.
Jeff
Old 01-01-2014, 11:46 AM
redefined's Avatar
Jeff
Not local to me. And this is how I was told to contact him from a tuner friend who has used him multiple times.
Thanks for the info though.
I'm just at the point I need to decide to do what I can NOW or build what I really want. Which might require building the motor and running it NA for a little till I build the turbo or s/c setup.
Old 02-04-2014, 05:36 PM
Windsor GTO's Avatar
Windsor GTO Windsor GTO is offline
Default other option
Bill Mitchell has a conversion that allows LS top end on SBC bottom end. Gets you the best of both worlds....worth looking into at least.
Old 02-04-2014, 06:05 PM
Bill Mitchell doesn't have the best reputation.
Old 02-05-2014, 03:39 AM
makoshark makoshark is offline
I went through this debate when I built my SBC. It ultimately came down, for me, to budget and already having a large amount of the SBC stuff sitting around.
If I were at that juncture right now, I would seriously consider an LS over the SBC, but there again it would come down to budget. However, to me, I wouldn't consider the 4.8/5.3 or the LS1. I have an LS1 now and didn't ever really consider using it. Those early LS motors are antiquated compared to the new LS3 setups. The LS3 has even nearly knocked out the LS2 out of the equation. I look at the LS setups now as having the ability to unshroud the valves. LS motors main benefit is the head design. The LS3 has the ability to run the LS7 style head and not constrict air flow into the cylinder. That gives you the ability to run the 11* heads with a large bore. All this takes out the early LS series motors out of the contention, to me.
With all that said, after tallying the final cost I have in my SBC, I could have easily purchased an LS3 crate or even built one for what I have in my SBC. I did, however, have a lot of SBC parts already purchased and sitting on my shelf that I did factor into the final cost of my motor build.
Old 02-05-2014, 04:46 PM
Che70velle's Avatar
The GM ls7 heads require a minimum of a 4.125 bore. The ls3 has a bore of 4.065, so it's a no go for the GM casting.
There are aftermarket companies making a "small bore" ls7 head that will work on an ls3.
Thanks Dad!!
