Old 01-07-2014, 07:01 AM
OBeer-WAN-Kenobi's Avatar
I respect the fact that some of us aren't made of money and you nearly have to be to buy a Mohawk lift. Those things are ridiculously expensive and part of the reason for that has more to do with Government contracts than anything else. Once you get on an "approved supplier list" where Government entities can just be lazy and buy your lift without going through certain quoting processes you can pretty much charge whatever you'd like. Mowhawk does have a unique feature with it's hydraulics but it isn't worth what they charge IMHO.
Certified is certified as long as it's the right agency doing the certs anyway. Yes, Chinese stuff usually is of a poorer overall quality, and I know how things are done in China; God knows I've been over there enough, but as long as it's certified, backed my an American manufacturer, and it's physically beefy enough I'm all for saving the money. I would NEVER get a Chinese; or American lift for that matter, if it isn't certified.
When you get to a certain point, it really has more to do with the foot pattern of your lift and the strength and quality of your concrete and anchors than the lift itself. Getting it installed properly and not being an idiot when you run the thing have at least as much to do with your overall safety. Most lift failures in the videos online that I've seen are anchor failures and improperly balanced or a load too heavy for the lift. Not even certification will save you if you pick up a crew cab diesel truck unbalanced with your 7,000lb lift on your 3" un-reinforced concrete.
'69 RS Camaro
'99 SWB Silverado LS "Beater"
'04 GMC Sierra 2500HD 4X4
My '69 Camaro Build Thread
Old 01-07-2014, 07:14 AM
jlwdvm jlwdvm is offline
I am already going to have to remove some sheet rock and maybe a little wood from the bottom of the spanning beams in my garage, so that narrows down what lifts I can use. After I remove the sheet rock I will have around 112" of height. The beams hang down about a foot from the ceiling. I talked to my installer and he spoke highly of Dover, which is the parent company of Rotary and Direct Lifts. regardless of what lift I get, it will be installed correctly on an over-done foundation and will be used properly. I am vet and used to work with animals that out weighed me by about 1800# and usually wanted to kill me. One thing I learned pretty quick was to think 2-3 steps ahead, use your head and always have an escape route....I guess that applies to working on 3500# cars too. You have to be smart working under jack stands too...and I've been doing that for too long as far as I'm concerned!
Old 01-08-2014, 07:26 PM
Sparks67's Avatar
Sparks67 Sparks67 is offline
Here is a few used Mohawk 2 Post lifts.
http://www.bethroseauction.com/prope...roperty_ID=543
My friend used to find these all the time, when he was in the hydraulic repair business. There is always auctions, tool companies going out of business, and companies that would want to get rid of slightly used equipment.
Jeff
Old 01-09-2014, 02:10 PM
coolwelder62's Avatar
My .02 is. You have a choice. There are great lifts made right here in the USA.I wouldn't even think about a china made lift if it can be bought here. I agree with Greg. It's a safety thing .The chinese don't care about safety. If something happen's their 6000 miles away. I could see if it was a saw or a grinder.But not a lift.
Old 01-10-2014, 05:52 AM
Jay Hilliard's Avatar
+1 on what Scott and Greg has stated. I got a used Rotary from a dealership. Mine was in great shape. Call you local Rotary/lift dealer. They have used ones all the time from expired leases, shops closing, etc.
Jay
Old 01-10-2014, 06:31 AM
Problem is that most shops aren't going to use a base plate lift, which I need due to my ceiling height restrictions. Got my 4'x4'x1' 5000 psi footings poured and finished last night. My concrete guy told me you could drive a semi on them in 5 days!
Old 01-13-2014, 04:24 PM
Moose Moose is offline
well thanks to this thread, I stepped back from buying one from greg smith equiment.
Ended up getting a rotary SPOA9. I was talking to a friend, and he had a friend that was selling the rotary out of his commercial shop. He needed it gone so he could get a 4 post for alignments.
picked it up for 900$. its a year and half old. SCORE!
Old 01-13-2014, 08:07 PM
Perfect!!!
Old 01-14-2014, 05:08 AM
wiedemab's Avatar
wiedemab wiedemab is offline
That's what I'm talking about.... I love my SPOA10!
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 01-14-2014, 08:06 AM
sniper sniper is offline
that's a really good deal.
I purchased 3 used Rotary lifts for $1050 each. They all are all about 6 years old. I recently had the cylinders rebuilt on one of them for about $300 for the pair.
The peace of mind of a good lift is worth it.
