Old 01-07-2014, 10:09 PM
Bill71 Bill71 is offline
Default Wilwood Calipers
I have a set of 4 piston Wilwood calipers for my rear suspension kit from Speedtech. The rotors are 13". I am planning to get a Wilwood 6 piston kit for the front with 13 inch rotors. My concern is the balance in piston area front to back. The 6 piston area is 4.04" and the 4 piston are is 1.96". This is a bit more than the typical 1.5-1.8 f/r ratio I have seen on here. Will this create a situation where the front is doing all the work? The car is a gutted 2nd gen Camaro which is built primarily for track days, not daily transportation. I want to do this right the first time as it gets too expensive to do it a second time! If this setup will work does anyone have a master cylinder recommendation? I am open to using a dual master setup too.
