Old 01-19-2014, 07:39 PM
goa484 goa484 is offline
Originally Posted by DETON8R View Post
Did you do a good measurement of the third member and verify the set-up on the third member? Often the pumpkin is offset from center to make sure the drive line has a few degrees offset.
Did the shop set up the rear end based on the pumpkin location or the true center of the third member (based on the hubs)?
Not really sure what the shop did. Pardon my ignorance but what is the best way to do this measurement? What am I looking for? Rear is 8.2 BOP.
Old 01-25-2014, 10:21 AM
DETON8R's Avatar
DETON8R DETON8R is offline
Sorry I didn't get back to you sooner, work is nuts and by the time I get home, the last thing I want to do is goof around with a computer.
Even if it is reading and commenting on my favorite subject.
I'm attaching links to instructions for a triangulated 4-link that Alston's Chassisworks sells, and while it probably isn't your specific setup, the concepts are the same for all triangulated 4-links. Setup for a 4-link isn't complicated, making the adjustments right can be though.
Check this out. See page 3 and the instructions for locating the center/canted brackets on a triangulated 4-link third member.
http://www.cachassisworks.com/Attach...ons/916720.pdf
If you really want to understand how this works from a system perspective, take a look at the G-bar/G-link instructions. Jump to the section that deals with setup once it is installed.
http://www.cachassisworks.com/Attach...915804-F10.pdf
It is important to make sure that the canted-link brackets are centered relative to the center of the 3rd member housing and not centered relative to the midpoint of the gear case. If you have a factory rear end, I'm sure it is fine. But if a shop set the brackets, it might be worth checking.
Adjusting the side-to-side location of the third member is done with the canted brackets.
Adjusting the "straightness" of the axle is the done by adjusting the length of the parallel links.
DETONATOR - 69 Camaro RS
Old 01-27-2014, 06:03 PM
Chassisworks Chassisworks is offline
Supporting Vendor
A 3/4" difference in the gap is only 3/8" difference in offset so that's not really very far out of alignment. You should be able to easily adjust that out with a couple quick turns of the upper bars. Did you get it sorted out yet?
Old 01-27-2014, 06:34 PM
Carl, could one redrill the leaf spring perch mounting plate to compensate for the rear end offset? Or is the offset built into the upper mounting bars too.
All GM cars seem to have this problem. More tire space on one side.
Old 01-28-2014, 10:26 AM
Supporting Vendor
Hey Vince,
The OP has a GTO so it came stock with a triangulated 4-link and coil springs but the instructions DETON8R posted are for our Camaro system which has a pretty comprehensive install guide. IF the car were a Camaro and it had the leaf plates, my answer would be NO, do not redrill. Just make the adjustments with the bars. If it were a leaf spring car then just buy new leafs. If that doesn't fix it then something is bent.
Regarding lots of GM cars being offset to one side; there is a reason. First, leaf springs suck, especially the ones built 50 years ago. Second, A and G body cars with stock 4-links are going to be prone to misalignment.
Here's why.
The stock lower arm's I-beam construction is designed to twist so as to prevent suspension bind. The driver side lower sees the most abuse. After a while it has a permanent twist which makes it slightly shorter and the car rear-steers left. The hot ticket back in the day was to swap it to the right side. (Then the car would go right until you had sufficiently damaged the other arm!)
The upper control arm crossmember is a relatively weak point in the system and prone to bending. This is why we recommend installing our control arm support braces on cars with decent power.
Old 01-28-2014, 07:29 PM
Thanks for the reply, my post was supposed to start with. On a Camaro....sorry for that.
Great info
Old 02-01-2014, 03:17 PM
Thanks! Im away from home now and just got to a place with internet. I ll try this when i get back and let you all know if that works!
Brad
Old 02-03-2014, 10:22 AM
Supporting Vendor
Great info
Yeah, that's what I thought but I wanted to make sure I was clear in case someone was skimming. I type fairly quickly so I sometimes words out which confusing some...
Brad
Great! Let us know how it goes.
