Old 01-20-2014, 10:15 AM
cwylie cwylie is offline
I have a ridetech front end kit on my car with the arms, spindles, coilovers and Im planning to get the true turn kit. I have the speedtech torque arm on the rear with ride tech coilovers. I liked the ride tech front setup better with the stock subframe and I liked the speedtech torque arm over the ridetech 4 link.
Old 01-20-2014, 03:30 PM
Rod P's Avatar
Rod P Rod P is offline
Originally Posted by OBeer-WAN-Kenobi View Post
I don't think mine will make it to the track but once a year if I'm really lucky but I want a good handling car. My current opinion is that ridetech fits that bill fairly well. Plus I can get both the front and rear suspension for less than a complete speedtech front sub
I race the Ridetech setup twice a month sometimes more, always one of the fastest cars on track
???why?? just curious
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 01-20-2014, 07:00 PM
Rod, I know you're a 1st gen but how difficult was routing the exhaust? Any reason you can think it would be different for me?
I appreciate the responses everyone. Please, keep them coming. I'm quite a ways out from doing anything, maybe later this year, so I have time.
OBeer, I think you'll be fine keeping your front subframe. I know the 1st gens aren't as good as 2nd gens from the factory, but based on how you think you'll be driving, I see no reason to spend the extra money on a new subframe. I consider myself to be in the same boat, and I intend to keep my factory subframe.
Old 01-20-2014, 08:07 PM
Rod P's Avatar
the Ridetech setup is a triangulated 4link, the same setup design that was used by gm on the chevelle from 1964 to whenever they stopped making the car, even my 2007 Jeep Grand Cherokee has the same triangulated 4link setup design, putting exhaust on a 4 link Camaro or TA is no different than any of those factory stock cars, every muffler shop can do it, should be pretty easy for them
personally I drove mine with the exhaust fully over the axle for 1 month and the drone KILLED me, so I had the shop cut the over the axle tubes off and now I run the exhaust turn downs before the axle and no drone, that was on 2.5 dia exhaust
Rod Prouty
Bangshift Stories
Old 01-20-2014, 08:35 PM
Thanks Rod. That's interesting you had more drone with the pipes over the axle.
Old 01-21-2014, 05:02 AM
Supporting Vendor
Our black 71 Camaro (if anyone remembers this car) had the exhaust run under the axle.
SUPER easy to install.
Nothing rubbed or hit.
All was good!
http://www.ridetech.com/garage/1971-camaro/
I know there are pics out there in cyber space of the exhaust on this car as this has been asked many, many times, but I didn't find them in the 3.4 seconds I took to look.
Skunk Werks
Ridetech
www.ridetech.com
Old 01-22-2014, 06:03 PM
brownz brownz is offline
All was good!
I also have my exhaust ran under the axle no issues at all
Old 01-21-2014, 06:20 AM
I liked that I was able to get it with all the tabs already welded to the axle from currie. Plus it looked like it freed up some room to run the exhaust above the axle. Im running ride tech shocks with with speedtech torque arm though.
