Old 02-01-2014, 02:05 AM
bret's Avatar
bret bret is offline
Supporting Vendor
Your tire hits the outer fender because the 265/45-18, at 27.4" tall, is about 1.8" taller than the 25.6" tall 275/35-18 tire that we (and most others) use. It hits the subframe at full lock because you've selected the wrong wheel back spacing by 1/2". Our printed recommendation for back spacing is 5.75".
If you install the correct parts on the car it will fit just fine.
Bret Voelkel
President
RideTech
Air Ride Technologies, Inc.
Old 02-01-2014, 11:38 AM
Rod P's Avatar
Rod P Rod P is offline
ummmm yep
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 02-01-2014, 01:28 PM
glr0212 glr0212 is offline
1st of all you cant make a hard BS recommendation because you don't know what my track width is. Depending on what brake setup people have the track width can move by as much as 1/2" or more.
2nd, and most important - If you look at the pictures the fender is practically sitting on the tire. adding an extra 1/2 of backspacing in my case and the fender will be sitting on the tire.
Basically I can not move the tire out towards the fender any more.
Old 02-01-2014, 01:31 PM
alignment
Camber -0.48
Caster +3.77
Toe in 0.03"
Old 03-31-2016, 08:39 PM
randy randy is offline
where do you live? if you are in dallas i would be glad to look at it for you
Old 04-07-2016, 07:47 AM
Thank you for the offer Randy, but I sold the subframe with the ridetech setup. I gave up on making it work and considered buying rehoops for the front wheels, but somebody bought the subframe so i went ahead and bought a DSE subframe. The DSE is workable with my existing backspacing.
Old 04-07-2016, 03:12 PM
you will love it. I love mine
Old 09-15-2016, 06:38 PM
HIFLYR's Avatar
HIFLYR HIFLYR is offline
OK
23 pages later and I am glad I have not ordered my ridetech system yet. Quick question about the set up for my 69 Firebird Conv. First I am not interested in autocross just want good handling on the road and adjustability in ride height. I am going LS 480 or 535 and automatic, while I want to run a larger front tire, I really do not care to have bragging rites for stuffing in the largest I can. Will this system work for fairly easy for a guy with my goals. I do not want to create a nightmare when buying parts etc.
Old 02-01-2014, 01:36 PM
The tire is a 25.3" tall
265/35ZR-18 BFGoodrich g-Force T/A KDW 2
thanks for your help.
Old 02-01-2014, 03:17 PM
dhutton dhutton is offline
but thanks for your help.
Your first post says it is a 265/45 tire....
Won't half height bushings tuck the tire further into the fender and aggravate the problem?
What about adding a litte more camber?
