Old 01-29-2014, 12:50 PM
Ricochet's Avatar
Ricochet Ricochet is offline
Hot rodders would use louvered metal plate... bead rolled... edged... pin stripped... metal flaked...
LOL
Car looks fantastic Brent!
Thanks Greg! Much appreciated!
Brent
Old 01-29-2014, 09:13 PM
Sieg's Avatar
Sieg Sieg is offline
LOL
........and peppered with rock chips..........unless you're building a trailer queen.
Old 01-30-2014, 01:42 PM
youthpastor's Avatar
Originally Posted by Ricochet View Post
OK, a little productivity for today. I was able to get the passenger inner wheel well done and tie it into the in the side panels. Took some time to get it all done. Hard when you have a rolled angle at the fender & it remains flat at the frame. I also was able to get the tranny cooler mounted. I was running out of options up front. So I opted to mount it behind the pass front tire. Should get plenty of air there. It's a stacked plate which cool extremely well, plus I went one size larger from their recommendation. They didn't think it would be problem with the location. I plan on using stainless mesh in the openings to protect the cooler from any debris. The inside of the wheel wells and panels will all by done in Raptor bedliner material. Now off the driver side which I already have a good jump on.
Um ya....I'm going to have to point cleco #'s 3 and 17 on the left side are off by 3 degress, not sure it will pass 200MPH.
WORK LOOKS AWESOME, STILL MY FAVORITE '55
[SIGPIC][/SIGPIC]
CHRIS HOLSTROM CONCEPTS
http://chrisholstromconcepts.com/
Old 01-30-2014, 03:11 PM
fleet's Avatar
fleet fleet is offline
Brent, aka the 'Tri-Five Man of the Year'.
Old 01-30-2014, 04:41 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Great stuff Brent. She's looking good!
Old 01-31-2014, 07:35 AM
Ricochet's Avatar
Thanks Chris!! I'll try to work on my cleco angles on the driver's side!
Not to sure about that Skip, but thanks for the encouragement! Would have been nice to have had this car done a few years ago as planned, really would have ben different and on the edge - but oh well. Haven't seen to many 55's in this flavor. Most are Street Rod style builds, which are great as well. Pro Rides is doing a killer 55 that is going to be real aggressive. Looking forward to seeing it done!
Thanks Tony!!
Brent
Old 02-04-2014, 08:14 PM
Ricochet's Avatar
Default Another Minor update
Yes...It's true another update. Who wudda thought? I think I have more updates in the past month than I have in the past couple years! LOL!
So I have now finished up the driver side panels and inner wheel well.
Before
After
With both sides now complete time to take action in the rear area. Going to tie it all together and run pans from the rear of the tub to the bumper. Thinking it will be 3 pieces. This will take some time. I have it sketched out what I'm looking for. We'll see how it comes out in the fabrication process.
Brent
Old 07-29-2014, 02:00 PM
Ricochet's Avatar
Been awhile since I have posted any pics but I have been making some progress in the rear area. I have tied the side rocker panels into the rear tubs and now continuing the rear treatment. The mufflers ended up hanging just a tad below the quarter panel. I had to extend the rear quarters about 2 3/4" in the rear but tapers off as it gets to the wheel well. Once this was done I was able to make the panels. I'm not sure how hot it will get back there but I plan on wrapping the mufflers and also cutting opening and using perforated metal for breathing. I'm pretty sure that will be enough. If anybody has any other ideas I'm open for suggestions. Last night I made the rear cover for the tank and looking at the lines for bead rolling. Have a crazy week this week but should be done next week.
Brent
Old 07-29-2014, 02:29 PM
Brent that looks AWESOME! Always good to make progress.
Old 07-29-2014, 02:48 PM
Lenie's Avatar
Lenie Lenie is offline
Brent, nice work. I tucked everything up tight also so I ceramic coated everything all the way back then header wrapped everything all the way back, covered my muffler tops with blankets and floorboards w/heat protection felts... alittle overboard but it looks good and works.. love your metal work and mad bead rolling skillzzzz...keep posting.
Lenie
