Go Back   Lateral-g Forums > Technical Discussions > How To's, Tips, and Tricks
Old 03-03-2014, 10:02 AM
TheCoatingStore's Avatar
TheCoatingStore TheCoatingStore is offline
AND --- If you're going to weld on a gas tank…. Clean it with plain old soap and water --- and either fill it with ARGON or CO2 "inert" gas --- or drop some DRY ICE in it and wait for it to "smoke" before welding.
This is a great tip. People get hurt every year welding on tanks. If you don't have Argon or CO2 readily available dry ice is at most walmarts now.
I can see how the exhaust gas would work as well but you are trading an explosion hazard for a carbon monoxide hazard.
Old 03-03-2014, 10:20 AM
dontlifttoshift's Avatar
When fabricating floors and firewalls and stuff. Save your templates! Not for the next car, but for when it comes back from paint you can transfer your templates to your favorite sound deadener and insulation and save a ton of time.
Donny
Old 07-25-2014, 11:23 AM
Blake Foster's Avatar
Here is how we do it.................... WE DON'T sorry sir you will need a new tank so we can weld it
Blake Foster
www.speedtechperformance.com
Old 07-25-2014, 10:48 PM
yep, plus the replacment stuff is so damn cheap now.
Old 07-26-2014, 04:45 AM
It's so easy the fat chicks can do it.
It's a matter of knowledge over listening to you buddies "theory" of what he heard about his grandpa used to do.
Old 08-05-2014, 07:47 AM
Wissing72's Avatar
Wissing72 Wissing72 is offline
This one is simple and easy. I started doing this years back. I noticed construction guys would hammer in blades into scrap wood. We have all noticed the container at the DR's office. I now have my little ones in the garage with me and do not need the accidents. I am sure the garbage man would appreciate it as well.
Just use an old coolant jug and cut a flap in it, MARK what it is and you have a safe containment for blades or other small sharp materials.
Chris
70 Chevelle. Roadster Shop Chassis, The shop llc/ Jon Lind interior LS3/6speed. Thanks to Precision Classics and Collision Eugene, Or. http://precision-classics.com/
Build thread:https://lateral-g.net/forums/showthread.php4?t=39517
Old 10-29-2014, 09:36 PM
Sieg's Avatar
Sieg Sieg is offline
Thanks to GW's idea I went and scored an old Carrillo SBC rod to use as a TIG torch holder (actually came out of a friends drag car) from a local engine builders junk pile out back, I used to hang out at this shop in the 70's when I was in high school which adds to the cool factor for me.
The rod wasn't exactly pretty when I picked it up, though it was a very uniform coating of heavy rust...........
After soaking in white distilled vinegar over night and brushing with a stiff bristled brush this is the results........
The rust literally fell off of it.
Old 10-30-2014, 07:11 AM
Hello.... THAT was not my idea... I only use vinegar to clean the coffee pot! I'd have walked that nasty azz rod right over to the bead blaster and 50 seconds later it'd be rust free...
THEN --- my idea was to make a TIG torch holder.... and that's where YOUR talent should begin.
HAHAHAHAHAHAHAHAHA
Will be a kool project.
Old 10-30-2014, 08:03 AM
jarhead's Avatar
jarhead jarhead is online now
I save cereal boxes because they are about the right thickness to use for sheet metal work. I use them for patterns to make sheet metal parts.
I had a thought the other day to build a template for a transmission hump. I covered the hole over my TKO with cardboard, used a 3" lid to get the diameter of the shifter plate.
I screwed the cardboard to the hole, covered it with wax paper, and then began the fiberglass layup process.
Fits like OJ's gloves
joe
Semper Fi
My 68 Torino
Old 10-30-2014, 01:03 PM
"If the glove doesn't fit, you must vote to acquit!" (or whatever was actually said)
Hope it fit better than OJ's glove! Thanks for the bad memories.... LOL
GREAT IDEA BY THE WAY!!!
