Old 03-11-2014, 08:44 AM
Reactor Reactor is offline
Exactly what I used. Less than 200$ for Camaro LS3 flywheel/clutch on Ebay and used the Magnum. Works fine. I used the Hurst Driveline Hyd T/O brg conversion parts and it bolted up with no fuss and works great.
Old 03-11-2014, 08:10 PM
MillerBuilt's Avatar
MillerBuilt MillerBuilt is offline
Originally Posted by samckitt View Post
I have an LS7 flywheel/clutch setup on an LS2 from a Trailblazer SS, so I bet the LS3 has the same bolt pattern.
Thanks for chiming in. Always nice to get multiple opinions/input!
More good news, thanks for adding to this! That is where I purchased my T-56 Mag (Hurst Driveline) and with it, came the TO bearing as you probably have.
Ok, one more question now that it seems as though everyone agrees the LS7 setup will fit an LS3. Is the LS7 setup the same as the LS3? Or is the LS7 a different/better setup to handle the additional hp/trq of the LS7?
Thanks, Jay
