Old 03-25-2014, 05:33 AM
surewhynot surewhynot is offline
most shops should be able to do it to the point where they will hold air, however your concern would be them scratching/ gouging the wheel. I would look at a specialty hot rod shop or custom wheel place. where are you located?
As far as balancing most shops will use sticky weights on the inside of the wheel when balancing aftermarket wheels. One thing to be cautious of is the sticking weights and your brakes, not a common problem generally but can be with larger brake upgrades.
