Old 04-09-2014, 06:23 PM
rickpaw rickpaw is offline
Originally Posted by goob8869 View Post
but the car will still not crank
Meaning the starter does not engage? If so, you need to check the wiring from the ignition switch to the starter solenoid.
Also, I can be wrong (have to dig out my LS swap books), but I think the ECU (99) is not compatible to the later year engine due to different crank position sensor (24 tooth vs 58 tooth).
Tu Ho
Old 04-09-2014, 06:42 PM
goob8869 goob8869 is offline
The starter turns over but will not hit a lick. The fuel pump and relays keep clicking. If I unplug the tac module it will fire up but no throttle then and as soon as you plug it back up something happens
