Old 04-24-2014, 11:53 PM
Certainly looks light weight.
Old 04-25-2014, 12:24 AM
Damn True's Avatar
Damn True Damn True is offline
Surprisingly so.
...the box that held the rotors though...ZOIKS!
Old 04-25-2014, 12:36 AM
what? you didn't get scalloped and drilled?
Old 04-25-2014, 12:46 AM
Drilled FTL.
Old 05-04-2014, 08:21 PM
Damn True's Avatar
You and I have been on these forums a long time my friend.
Brake system assembly began today though somewhat truncated by an insidiously progressive "honey-do" list.
Two steps forward and one step back in the form of a wheel stud shoulder that is .020 bigger than the hole in the Wilwood hat.
Old 05-05-2014, 06:03 AM
Ketzer's Avatar
Ketzer Ketzer is offline
Thank God somebody besides me has this kind of luck.... only twenty thou? Bigger hammer!
Jeff-
Old 05-05-2014, 09:21 AM
Jeff-
Good step drill will solve that.
Old 05-05-2014, 09:25 AM
Damn True's Avatar
Yep. I'll be making small holes into slightly bigger holes tonight.
Such is the challenge of systems integration.
Old 05-05-2014, 09:27 AM
Damn True's Avatar
Jeff-
Yep, but it's enough to keep the hat from seating all the way down on the flange. The shoulder on the stud is ~.520 and the hole in the hat is .500 exactly.
The hats index to the ring on the flange so boring them out with a step-drill shouldn't cause a problem.
Old 05-05-2014, 09:30 AM
Damn True's Avatar
Forgot to put the posts back that were lost in the server debacle, this and the next are from about 2wks ago...........
So the last substantive fabrication/welding task was to finish the install of the Lateral Dynamics 3-Link. I had the front x-member in before work stalled.
The remaining bits were installing the rear x-member, closing out the torque box, and installing the close-out panels/boxes to make room for the upper trailing arm.
Here's the rear x-member installed. I had it powder coated in a light gray. I hated to cover up Matt's welds, but the guy at the PC shop said a clear PC would discolor and look really lousy.
For some reason, I really enjoy doing those rosette welds. They're just kinda fun. As you can see, I had to put a doubler on the frame to take up the gap between the length of the x-member and the width of the frame. James had to pound his frame rails out to make his fit. Yeah late-60's manufacturing inconsistencies!
Here's the torque box closeouts. I hadn't finished grinding the welds down when I snapped the pic. Kathy was calling me to dinner.
Then I roughed in the trunk pan closeout and the doghouse that houses the upper link on the rear end housing.
