Old 05-01-2014, 03:06 PM
57hemicuda's Avatar
57hemicuda 57hemicuda is offline
Most of the time on RACECARS, they drive power steering off of the dry sump pump.
Old 05-01-2014, 08:52 PM
Originally Posted by gerno View Post
Is there any issue with exhaust flow in using a pipe like this or a full rectangle vs oval or round? I like the idea, especially after trying to run my exhaust this week. It's almost impossible to get that stuff tucked up.
As far as shape with the transition from collectors (round) into a sort of "D" section, all I can find on the subject, technically, says to have the "D" section at least larger than the round section, in an ideal world of course.
My math shows this:
3.5" round = an area of 9.62 sq inches
2.25" x 5" "D" = approx 9.06 sq inches (it's not a perfect semi-circle D shape as you can see in the pics)
So, essentially, it's close enough by my estimation.
If anyone sees my math wrong, please share your thoughts.
Old 05-01-2014, 09:02 PM
Originally Posted by 57hemicuda View Post
You need to send that baby to the east coast, I have some "Big American Bulges" in mind for that car that would be wicked. Looks awesome Dave.
Ha. Would be cool if I had 2 68's to see how a set of yours would compare to a set of mine. Wait, that doesn't sound right...
Hey, I've got an ... you do Payton's flares and there's your battle of the bulge(s).
All those steroid injections have turned BMF into a real Beast!
Hopefully no testing of that kind around here.
Dave,
I can't tell from the pictures, but are you running a power steering rack or a manual rack? I don't see a pump, so I was curious if you plan to steer those big-assed front tires without a little assistance.
It's the same Ford rack that you should have, unless you changed something. Jones PS pump assembly will be going on in a bit.
Whew. It's good thing mine is running a standard crank/water pump driven one then. I'd hate to be thrown into that RACECAR category.
Old 05-01-2014, 09:07 PM
Got to sit in my new Butler seat. She's nice and snug and fits me well. Because I have been on the Payton bench press and lat pulldown program since I left North Carolina, we need to stretch out the rib tabs a bit. Otherwise it's all right where it needs to be.
We threw the head and shoulder pieces on as well while we were fitting the pedals and column, and they were much less intrusive with respect to the cage bars than we were anticipating. So that was good.
Old 05-01-2014, 09:13 PM
carbuff's Avatar
carbuff carbuff is offline
Got it. I did replace mine with an AGR rack, but it is the Ford compatible one...
Old 05-01-2014, 09:18 PM
Ohhh you did eh? I recall you had a steering issue but did not see you replaced it. Did it fail completely or you simply decide to upgrade/change?
Old 05-02-2014, 04:05 AM
57hemicuda's Avatar
I like the over stuffed green one in the picture way better. Looks like you could drive all day in that one.
Old 05-02-2014, 06:05 AM
Last one of those I saw was in....................... a race car.
LOL
Man that thing is awesome! It'll be perfect in traffic on the Bay Bridge!
Old 05-02-2014, 08:35 AM
It will be perfect for reaching back to put the pacifier back in the babies mouth.
Old 05-02-2014, 08:38 AM
Track Junky's Avatar
Thats the most comfortable looking street car seat I have eve seen. Are you going with electric adjustable tilt and front to back
Car looks wicked Dave!!
Gaetano Cosentino
