Go Back   Lateral-g Forums > Events > Track and Driving Events
Old 05-11-2014, 08:21 AM
Track Junky's Avatar
With one guy lying, and the other guy swearing to it.....
Keep fueling the fire gramps
Gaetano Cosentino
Old 05-11-2014, 09:29 AM
73CPCAMARO's Avatar
73CPCAMARO 73CPCAMARO is offline
We been using that term "he ran out of talent" and "he had it under control right up until he lost it" for 20+ years.
It's funny reading this tonight because the guy pitted next to us crashed, we asked what happen? He said "I just ran out of talent while trying to make that pass"
I have used this on myself and others for a long time. No insult meant at all. It is just used to explain a driving failure of some type and not a mechanical failure. Can't blame the car on that one.
Brian Hobaugh
1965 Corvette
1973 Camaro
2003 Z06
Old 05-11-2014, 10:04 AM
Sieg's Avatar
Sieg Sieg is offline
...........and that's when the fight started.
Old 05-11-2014, 10:33 AM
Thanks for clarifying Brian.
What, I don't get a handicap for narrower track width, narrower tires, and sub par suspension? OK fine. Tell you what Cheese Ball........ If I knock down something in between 2:00 & 2:01.9 in a couple of weeks the nick name Cheese Ball is gonna grow legs to your neck.
don't use your so called handicap for an excuss. Its your choice to be fast or not.
"FIGHT"
Old 05-11-2014, 01:23 PM
"FIGHT"
I'd have to say at this point my downfall is front shocks. Single adjustable QA-1's just don't cut the muster and even though I finally got the front to stick better I can still feel a bit of bounce. Hopefully in a couple of months we can get the chicane deal and the front coil overs installed.
Gaetano Cosentino
Old 05-11-2014, 01:55 PM
You know what they say about the guy that makes too many changes at once don't you?
Old 05-11-2014, 02:00 PM
Geez, what a knitting club over-analysis of something.
Mary Pozzi has been using that phrase for years in this community and she probably heard it from someone who'd been using it for umpteen years prior to that.
If you don't have talent, then there's nothing to worry about.
If you do have talent, don't run out of it while your buddies are around and/or while the GoPro is running.
Brian -- nice times on street tires. Looks like you got some work to do, Gaetano.
Originally Posted by Damn True View Post
It's fairly common parlance amongst racers. In that context it isn't meant as an insult. It's a means of explaining in simplest terms that at the absolute limit sometimes stuff happens that one simply is unable to compensate for. "Stuff" can be mechanical, or driver error and it happens to everyone. Schumacher ran out of talent once in a while, Senna once too often. Certainly doesn't make them lesser drivers.
That said, HPDE drivers should never be that close to the edge of the envelope of either the ability of themselves or the car.
Talent is what keeps you out there on the edge of failure...once you have extended your reach of your personal talent, things break or you do things unintentionally. This includes your knowing the cars ability.
Old 05-11-2014, 02:08 PM
I ran out of talent at nearly every event I attended. That's how you learn the weaknesses of your car and driving skills. As you gain experience and confidence as a driver, you continue to find faults with your car as you gain speed. As you fix those faults, then it's back on you as a driver to find the line in the sand again.
Old 05-11-2014, 04:33 PM
intocarss's Avatar
Spoken for the truth
Old 05-11-2014, 05:20 PM
Good thing you quit when you did! HAHAHAHAHAHAHAHAHAHA
Sorry dude! Just couldn't help myself....
