Old 05-23-2014, 05:30 PM
can you do 21 1/4" on one side then 21 1/4" on the other?
Old 05-23-2014, 06:37 PM
tumper93 tumper93 is offline
That is kinda what I was thinking also and equal them. I understand staggered for leafs but no need for that now. The pinion is offset in the rear end also to keep the joints out of phase. Figured I would see what others thought and it looks to be the same. As long as the swaybar fits we will be good
Old 06-05-2014, 10:04 PM
DETON8R's Avatar
DETON8R DETON8R is offline
Talk to Carl or Mike at CAC.
Are you using the sway bar for a mini-tubs or standard tubs?
When I had the brackets welded on the rear the sway that I purchased had the aluminum arms, and the sway bar was a bit too wide. I had to cut it down and re-weld new end spuds on the sway bar.
DETONATOR - 69 Camaro RS
Old 06-13-2014, 11:31 AM
Chassisworks Chassisworks is offline
Supporting Vendor
Tumper,
I'm looking at the engineering drawing for a mini-tub housing right now. Here are the dimensions you need.
Driver side is 21.5" from the pinion centerline to outside of bracket.
Pass side is 20.5" from the pinion centerline to outside of bracket.
That centers the brackets under the car.
If you have the splined end, billet arm anti-roll bar it is helpful to just stick the bar in between the brackets and use that to help with fixturing. Also, here's some help for the angle of the brackets.
With the face of the housing at 90 degrees to the ground, the bottom edge of the LCA bracket should be 4.5 degrees below level.
If you have any more questions, call us and ask for Mike. I will be away from my desk most of the day taking pictures of some trick new parts.
