Old 05-27-2014, 06:49 PM
rocketrod rocketrod is offline
Originally Posted by Bmf5150 View Post
What are the cost on these ??
Summit Racing sells them, p/n 56-00010 http://www.summitracing.com/parts/ci...t/model/camaro
Rod
1969 Camaro - LS2/4L70E
Old 09-17-2014, 02:38 PM
MattG's Avatar
MattG MattG is offline
Rod,
Tried sending you a PM, but your inbox is full!
'69 Camaro Coupe, Full Ridetech stage 3 suspension, moser wavetrac 12bolt, Forgelines, Ls3 Heads/Cam,T56 Magnum. Built by me and tuned by Ed!
'69 'Vert Camaro: DSE Sub-Frame, DSE Mini-Tub, DSE Four-Link w/9inch. LME LS7 427, T56. Tuned by Ed Hutchings, :SOLD!
Old 10-25-2014, 10:41 PM
Is this bigger than the factory heat exchanger?
Old 10-26-2014, 09:20 PM
snappytravis's Avatar
snappytravis snappytravis is offline
I am not sure what you mean by the factory one, it .mounts in front of ac condenser. It is pretty good sized I think bigger that what you would see in a ctsv caddilac. I ended up using a pump from lingenfelter for mine and purchasing several hoses with 90 degree bends worked pretty good.
Old 10-28-2014, 03:08 PM
Yes I meant Caddy or ZL1. I guess I didn't articulate my question very well
Old 10-28-2014, 04:32 PM
I thought that was what you meant, I think they may be a tad bit bigger, Just curious how much is a zl1 or Cadillac exchanger?
Old 10-28-2014, 04:35 PM
Default afco zl1 heat exhanger
http://www.phastekperformance.com/20...nger-80283.htm
I think this style is not as tall but thicker. I like the fans,, have to build some brackets to mount. The cr racing on bolts together pretty good.
